#43 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
Looking for a little advice from those of you that installed a header to the stock overpipe. I got a second hand header without any hardware so I’ve bought the necessary gaskets but I have no idea what size/length of bolts I will need to attach the stock overpipe to the header. Can you help with advice as to what you used?
#44 |
Drives: 2015 Scion FR-S
I have UEL catless Gruppe-S +flash with stock everything else. So far I like it. it has the rumble but doesn't drone at all. I would like the rumble to be more pronounced but I'm going to get exhaust at some point for that. for now i really like it.
#45 | |
R400 Perrin 2.5 MXP SP/ CSG touring Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
#46 |
Drives: 2017 BRZ Limited PP
Figured I'd add to this thread since I just put my BRZ back to stock and traded it.
I ran a JDL catless UEL header with the corresponding OFT OTS tune for a while. There were no other modifications on the car (i.e., the rest of the exhaust was stock). I also made the JDL specific valve timing changes that I found on the forum to the tune. Overall, I liked it. The car was legit faster in almost any scenario. It turned the original three part powerband (initial torque hit, dip, then torque's back...) into a two part powerband with a low and high end. Though, I swear the car lost torque between 2K and 2.5K rpm. Regarding sound, I can see why some might not like it. It had a bit of a nasal quality to it. Overall, I was cool with it. If I were to do it again, I might go equal length, I'm not sure the uel rumble thing is for me. Regarding volume, a lot of people say it barely increases volume. I'd say it notably increases volume but it isn't too loud. I wouldn't want it any louder, but then again I'm a pretty understated person and like to exercise a vehicle without alerting everyone or drawing attention. |
#47 | |
| Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp | fooddude | Engine, Exhaust, Transmission | 11 | 08-11-2016 07:18 PM |
| Aftermarket catted front pipe with stock catback | Aenv | Engine, Exhaust, Transmission | 1 | 12-07-2014 12:30 PM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| Aftermarket Catback (Q300) but using the stock muffler. | Wise | Engine, Exhaust, Transmission | 11 | 10-16-2014 02:42 AM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
