Old 10-19-2018, 07:41 PM   #15
Originally Posted by stlgrym3 View Post
Question is do I need to have to do a tune revision when I switch back onto stock catback while still running ACE header and flex fuel kit?
Not needed!
strat61caster (10-19-2018)
Old 10-19-2018, 07:41 PM   #16
+1 It's fine and probably the best power/volume ratio out there.
[ame]https://www.youtube.com/watch?v=qNLKubCqMhk[/ame]
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
akyp (10-20-2018), JonAvalon (10-19-2018), Lantanafrs2 (10-20-2018), strat61caster (10-19-2018)
Old 10-20-2018, 03:33 AM   #17
ShansBRZ
Drives: 2017 brz
I’m running a catted UEL header with aftermarket over pipe and a catless dual resonated front pipe with the stock cat back currently on a stage 2 tune. I like the quiet but do wish it was a bit louder.
ShansBRZ is offline   Reply With Quote
Old 10-21-2018, 12:35 AM   #18
How much louder do you want to be?
Old 10-21-2018, 12:55 AM   #19
byun
byun's Avatar
Drives: 2015 BRZ CWP
I’m running the ace a350 and ace front pipe with stock catback. It’s pretty quiet but buzzes and sounds like crap at certain rpms
byun is offline   Reply With Quote
Old 10-21-2018, 02:25 AM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm probably the only guy running a Borla EL with the stock exhaust. I like the sound. A bit more revvy.
Old 10-21-2018, 04:20 AM   #21
ShansBRZ
Drives: 2017 brz
I like the low subi rumble that a N1 has but hate the loud drone after the RPM’s get around 3k.
If they made something that gave me both the low rumble but quieter at higher revs I probably would get it. Asking for a lot I know. Lol
Old 10-21-2018, 06:57 AM   #22
It's not. Check out the Touring86.
Old 10-21-2018, 09:25 AM   #23
86TOYO2k17
Drives: 2017 toyota 86
Did you hammer down your skid plate? Ace headers rub that. It may look like it has 1/2” clearance but under load engine shifts and header rubs. If it’s happened awhile you should see rub marks on header and skid plate and know exactly where to hammer out.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
gtengr (10-21-2018)
Old 10-21-2018, 09:54 AM   #24
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Also running an aftermarket header, stock catback. Turbo is going on with stock catback as well. If you enjoy the car, who cares if you lose a pissing match on a dyno sheet? Put the money you've saved into an oil cooler or tires
Old 10-21-2018, 03:31 PM   #25
stlgrym3
Drives: 2017 Subaru BRZ Limited
I’m just surprised how quiet the car is now with the stock catback. I know it’ll be quieter than before but this is almost exactly stock-quiet. Doesn’t header by itself make the car louder? I’m not complaining just curious.
stlgrym3 is offline   Reply With Quote
Old 10-21-2018, 04:20 PM   #26
JIM THEO
Drives: BRZ 2018
Gruppe-S UEL headers + overpipe, little more rumble but more or less OEM like, and when you thrash it (depends also from your map) it has the nice boxer sound!
JIM THEO is offline   Reply With Quote
Old 10-21-2018, 06:47 PM   #27
byun
byun's Avatar
Anyone runs aftermarket header with stock catback?
Yea I’ve hammered my skid plate in a few spots also have Cusco motor mounts.
The buzzing is from the stock catback since I’ve full catless with no resonator in the front pipe.
Old 10-21-2018, 07:53 PM   #28
86TOYO2k17
I ran ace, with hks FP, and stock exhaust. It didn’t really buzz. But personally I thought it sounded bad. Hard to explain something just sounded off. So I got the CSG touring86 didn’t make it louder but deepend and crispened up the sound. Now it sounds right. Just my opinion and experience.
bhmax (10-29-2018)
Search this Thread:
Advanced Search
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 07:18 PM
Aftermarket catted front pipe with stock catback Aenv Engine, Exhaust, Transmission 1 12-07-2014 12:30 PM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
Aftermarket Catback (Q300) but using the stock muffler. Wise Engine, Exhaust, Transmission 11 10-16-2014 02:42 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
