Old 09-28-2018, 05:24 PM   #1
Rai-zero
Drives: Legacy
tS Lightning Lap (Car and Driver)
I'm always one that says I'm not caring about how fast the BRZ is but it's still interesting to read about.
I am not sure how you can compare the times (when they come form different years) but nonetheless the tS was 5.7 seconds quicker than the 2017 BRZ with PP (tested last year) (**Tires**). So in other words same brakes, power, gearing but with the STI tuning and tires changed.
tS was 0.6 seconds quicker than 2017 Civic Si and 2016 GTi.
1 sec quicker than 2008 S2000
The same time as Golf R ($40K 2012).
Again this is hard to say who know if conditions were better or worse in years past? But that's what we have to look at.
here's the links :
https://www.caranddriver.com/feature...tning-lap-2018
https://www.caranddriver.com/feature...inglap2018cars
Subaru is paying attention. When the BRZ first appeared at Lightning Lap 7, we applauded its sharp handling but asked for better brakes. Last year, the Performance package delivered binders that shrugged off repeated abuse but had us hankering for more grip. In its third coming, in tS form, the BRZ gets more stick courtesy of Michelin Pilot Sport 4 rubber. The Brembo brakes take full advantage of the newfound tack. Ignore the placards for braking zones five and four, drive it deep, and stand hard on the center pedal after the third marker and the tS slows with herculean force.
The BRZ has always been a momentum car. One hiccup and the lap is toast. Maximizing pace means minimizing time spent below 5000 rpm, keeping the flat-four revving to avoid the canyon-sized dip in its torque curve. Slipping and sliding through turns used to be the fastest way to carry speed in a BRZ around the Grand Course, but now that the Subaru has more traction, exploiting the 205 horsepower demands greater control. The 2834-pound BRZ stays glued through Hog Pen, recording this year’s fifth-fastest minimum speed (69.1 mph) through that turn.
The chassis is rear-drive philosophy perfected—precise and responsive. The stiffer STI-tuned springs and Sachs dampers work in harmony with the additional structural bracing to erase body roll. The updates make for a noble 3:14.0 lap. For you club racers keeping tabs, that’s 6.8 seconds quicker than the Mazda MX-5 Miata Club from 2016. The BRZ might not be the fastest car here, but it is one of the most fun and rewarding to drive at the limit.
Rai-zero is offline   Reply With Quote
Old 09-28-2018, 05:47 PM   #2
Chuckls
Moutain Runner
https://www.ft86club.com/forums/showthread.php?t=130390
Chuckls is offline   Reply With Quote
Old 09-28-2018, 06:16 PM   #3
Rai-zero
Drives: Legacy
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 11:28 AM
Firestorm vs Lightning Red Djmikec Scion FR-S / Toyota 86 GT86 General Forum 11 03-23-2015 11:09 PM
The lightning lap Gixxersixxerman FR-S / BRZ vs.... 35 09-17-2014 01:15 PM
Car and Driver: Lightning Lap 2013 (BRZ competes! LFA TOO!) Chewie4299 BRZ First-Gen (2012+) — General Topics 19 09-11-2013 03:51 PM
Lightning Red Ft 86 Acid18 Member's Car Journals 6 12-28-2012 02:27 AM
