#15 | |
JHerbert Racing
Drives: 2013 Scion FRS
I am almost still certain that its your EPS cutting out bc that has been a known issue. But the fact that our tires are hitting the chassis can't be good either.
#16 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
This was with R888R 255/40/17 however since then I have moved to R7 225/40 and been tracking at different locations and no issues. Unsure if its a Glen thing or a big wider taller tire thing or both. Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
#17 | |
Drives: Track preped NA FRS
@lutfy 255/40 has a lot more sidewall than 225/40. Specially since the R888R has so much tread (9/32). Pretty sure your issue was this same thing. Edit: grammar correction. Last edited by Icecreamtruk; 09-27-2018 at 02:47 PM. |
#18 | |
JHerbert Racing
Ur issue could be the fender, it may not but just know the EPS cutting is also a known issue. Sent from my SM-G965U using Tapatalk
#19 | |
![]() ![]() ![]() ![]() Did not think it was related but YES YES YES my fenders were rubbed pretty badly and we had to raise it 1/2 inch. This all makes sense now. Cheers guys. Lutfy
| The Following User Says Thank You to lutfy For This Useful Post: | Icecreamtruk (09-27-2018) |
#20 |
It's tread, not thread.
idk why this has been popping up more and more recently but it bothers me. ![]() https://www.tirerack.com/tires/tiret...e.jsp?techid=9 |
| The Following User Says Thank You to strat61caster For This Useful Post: | Icecreamtruk (09-27-2018) |
#21 |
This has happened to me before. In my case, I can see a mark on the inner wall of the wheel well where the back of my end link was hitting it under high compression sweeping turns.
| Steering issue under braking ! | AJ PwR | Tracking / Autocross / HPDE / Drifting | 146 | 04-25-2023 06:47 PM |
| Possible Steering Issue ? | TJB_902 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 06-24-2015 02:38 AM |
| Watkins Glen HPDE - 4/25/15 - 4/28/15 | Takumi788 | Tracking / Autocross / HPDE / Drifting | 23 | 04-21-2015 09:30 AM |
| Watkins Glen Sunday ! | GT86Dan | NY / NJ / CT / PA | 0 | 06-25-2014 12:31 PM |
| Steering wheel issue | Khalis | Issues | Warranty | Recalls / TSB | 1 | 05-04-2013 02:19 AM |
