86WORX
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 09-24-2018, 01:33 AM   #29
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Buy an SUV.
Old 09-24-2018, 10:23 AM   #30
JD001
JD001's Avatar
Drives: Subaru BRZ
Some alternative options if you really must keep the Twin:
Old 09-24-2018, 11:16 AM   #31
gravitylover
If you can't get a good approach angle a lip will just increase your issues not solve them. By extending the bumper down and forward you reduce your clearance even more. Best case scenario you just rip the lip off. Worst case it hold and breaks the bumper clips creating sag.
The bottom of my bumper is worn down from scrapping but it can't be seen so I just live with it.
I've got a pretty good case of saggy bumper
I really want to rally mine out like this when I get the car paid off. There's one running around my area that's lifted a good 2+" and I think it looks like a whole bunch of fun.
Old 09-24-2018, 11:34 AM   #32
JD001
JD001's Avatar
Drives: Subaru BRZ
Hold on.... "I really want to rally mine out.." why so bothered about scarping the bottom of the car if that is the end game?
Old 09-24-2018, 04:02 PM   #33
gravitylover
Ehh, I'm not too worried about scraping it up but I don't want to knock anything (else) loose or damage the exhaust. If I was really worried about it I wouldn't spend time playing around on dirt roads as often as I do especially after I switch back to the winter wheels and tires soon. The front bumper is probably already a lost cause if I don't pull it off soon and replace a few of the clips.
Old 09-24-2018, 04:38 PM   #34
Bet you aren't so fond of gravity now are you?
gravitylover (09-24-2018), JD001 (09-24-2018), mnuttall (09-24-2018)
Old 09-24-2018, 07:34 PM   #35
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Any weight removed from behind the rear wheels is going to lower the front.
I actually passed on an otherwise nice house because I scraped my FRS bumper on the driveway lip. That damage still makes me sad every time I change the oil....
No, that is not how it works. Not even remotely. Any weight removed from anywhere will raise the car a bit. Remove 100 pounds and it should stop the car from scraping on anything but the worst entryways or hills.
Old 09-24-2018, 08:38 PM   #36
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The moment about the rear axle has to be 0. Sum the force vectors on both sides, the remainder is supported by the front axel as an upwards force.
By decreasing the weight behind the rear axle you reduce that part of the force vector sum. Meaning the front actually has a greater force on it, since the moment around the rear axel must still be 0.
Greater force on the front, more spring compression.
Old 09-24-2018, 08:52 PM   #37
Even if it raised the car equally I doubt that a 3.5% weight reduction spread across the whole suspension would make any real difference in ride height at all. Certainly not enough to prevent scraping unless you were just touching by a c-hair.
Old 09-24-2018, 09:06 PM   #38
Spuds
The Dictater
Spuds's Avatar
Well, I never said anything about scale. Just relativity. Of course it won't change by any noticable amount. We are talking 50lb vs a total of 2750lb.
Old 09-24-2018, 09:13 PM   #39
I didn't imply you did say anything about scale. I was just adding to your comment.
Spuds (09-24-2018)
Old 09-24-2018, 10:07 PM   #40
gravitylover
Smartass
The Following User Says Thank You to gravitylover For This Useful Post:
Tcoat (09-24-2018)
Old 09-24-2018, 10:09 PM   #41
Smartass
chaoskaze (09-24-2018), gravitylover (09-25-2018)
Old 09-24-2018, 10:41 PM   #42
JD001
JD001's Avatar
Drives: Subaru BRZ
Just stick on the rally springs/shocks for now and get the rest of the rally kit later.
Search this Thread:
Advanced Search
driveway scraping Toyarzee Scion FR-S / Toyota 86 GT86 General Forum 54 01-20-2015 08:18 AM
Clutch scraping noise 8 six Scion FR-S / Toyota 86 GT86 General Forum 31 01-05-2015 03:39 PM
Never trAcked my car Nd looking forward to it...help?!? Jonoraven93 Southeast 16 11-08-2013 05:11 PM
Lowered on coils- scraping Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-04-2013 05:41 PM
Protective Guard for Front Bumper from scraping? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 4 02-17-2013 09:16 AM
