Old 08-04-2021, 10:57 AM   #379
J95
J95's Avatar
Originally Posted by JBezugs View Post
I would definitely go with an Remote E-Tune with CSG or Delicious Tuning w/ ECUTek if you don’t have a tuner in your area. This way you are still getting a proper, tailored tune for your vehicle, vs an off the shelf tune that isn’t 100% optimized for the header or your particular vehicle.
Well, I will have to consider it.. But I read that the OFT is quite good already for NA (I will not go FI)
Suppose I already have the ecutek Dongle. How much will I have to spend then to get the proper tune with 4-2-1? I believe also I need to pay a license?
AFAIK oft is way more economic, also considering the post-selling price
J95 is offline   Reply With Quote
Old 08-04-2021, 11:53 AM   #380
jflogerzi
jflogerzi's Avatar
Originally Posted by Cephas View Post
Are you on a Flex Fuel kit or nah?
Yes. It was using E50
2013 Series 10 FRS #553
Old 08-04-2021, 11:56 AM   #381
jflogerzi
jflogerzi's Avatar
Originally Posted by J95 View Post
Thank you so much for sharing!
Mine is coming soon. I am planning to buy an OFT, as there are not reputed tuners in my area.
The OFT with the provided stage 2 tune should be fine right?
I will run JDL 4-2-1 with stock FP and stock catback. Soon I´ll change to an AM resonated catback
Imo you can get away with OFT just get a custom tune from one of the members on the boards. Just like the ace header it requires a much different cam settings/config which if you use the standard oft tune you will be leaving alot of power and driveability on the table
The Following User Says Thank You to jflogerzi For This Useful Post:
J95 (08-04-2021)
Old 08-04-2021, 12:14 PM   #382
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
You can also get a custom tune from OFT. Its a few rounds of data logging and sending files but it works well.
https://www.openflashtablet.com/shop/custom-e-tuning/
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 08-04-2021, 12:30 PM   #383
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
From Delicious Tuning? Sorry if you already said somewhere.
Cephas is offline   Reply With Quote
Old 08-04-2021, 12:31 PM   #384
jflogerzi
jflogerzi's Avatar
Zach at CSG
Old 08-04-2021, 04:16 PM   #385
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
So today was the day. Sadly the old girl's motor is seasoned and is down a bit on power. CSG uses a hub dyno similar to mustang number. I forgot to grab a screen shot that I could see but here where the final numbers:
170WHP Peak
152WTQ Peak
Gained 12-15WHP vs stock car through the entire rev range and peak up to almost 25WHP vs stock. TQ dip is 95% gone with E50 and E20(tuned like 91) its greatly reduced and shifted further in the rev band.
Talking with Zach he was happy with car considering the following:
-Car at the top end was losing about a 1LB of vacuum (could have been caused by Dyno Airflow vs real world)
-Car has stock FP with secondary CAT
-Engine has 83K miles on it
-DI have never been serviced. (he mentioned this could add back 5-10WHP)
-Fairly hot temps (mid 80s to low 90s when we were done)
So all in all compared to the e-tune before power is better but its the smoothness that is much improved. Throttle response also feels better. So with Ace or JDL 4-2-1 dyno tune seems worth it right off the bat if available.
On a Side Note on a dyno jet numbers would between
185-190WHP
162WTQ
Any comparison against the ACE?
Old 08-04-2021, 04:23 PM   #386
jflogerzi
jflogerzi's Avatar
Sadly he did not have any onhand to compare. I tried probing him for number and he would not give sadly.
Old 08-04-2021, 06:02 PM   #387
Mike_ZN6
Mike_ZN6's Avatar
I honestly think CSG does not want a direct comparison between these two headers.
The Following 3 Users Say Thank You to Mike_ZN6 For This Useful Post:
DocWalt (02-22-2022), Goingnowherefast (08-04-2021), Hades (08-07-2021)
Old 08-04-2021, 06:07 PM   #388
jflogerzi
jflogerzi's Avatar
You could be right. Honestly can't go wrong with either imo and JDL is cheaper so...
Old 08-04-2021, 06:09 PM   #389
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
I suspect the two will perform the same or at least within the noise floor of the data. In which case the question is, why would someone pay an extra ~$1,000 for a similarly performing header which basically requires you to upgrade engine mounts and has a history of cracked welds? That's a good question..
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following 3 Users Say Thank You to Goingnowherefast For This Useful Post:
Hades (08-07-2021), Mike_ZN6 (08-04-2021), PulsarBeeerz (08-06-2021)
Old 08-04-2021, 07:43 PM   #390
jflogerzi
jflogerzi's Avatar
Logic can escape ppl... but just be thankful we have options and JDL produced a really solid Header. Look at the weld quality on this overpipe cause I left it raw.
Stonehorsw (08-05-2021)
Old 08-07-2021, 12:08 AM   #391
Hades
Hades's Avatar
Drives: 2013 Scion FRS
The fact CSG hasn't released a dyno comparing JDL EL 4-2-1 vs. Ace 350 speaks for itself IMO. They seem to have a dyno comparing every other alternative header. Pretty sure if/when we get an independent dyno this JDL EL will be at least as good as or even better than the ace (maybe with a bit less midrange from what I've eyeballed in the dyno graphs).
Hades is offline   Reply With Quote
The Following User Says Thank You to Hades For This Useful Post:
Goingnowherefast (08-07-2021)
Old 08-09-2021, 07:04 AM   #392
J95
J95's Avatar
So guys I have already my headers ready to mount, and I decided to order an OFT. But it will take time to be delivered to Europe...
So I´m wondering if mounting my headers before receiving the OFT would be any perjudicial to the engine... I have a holidays trip in between (a bit less than 1k miles), and I´m looking forward to mount it already What do you think?
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 03:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
