#351 |
Drives: 2016 Scion FRS
Good luck getting the STi mounts. And if you find 2 sets, let me know!
I haven't noticed the issue with the subframe and I'm on stock mounts launch the car hard for autocross. My concern when I put the header onto the car is that there is only maybe 2 or 3 mm between the tubes and the radiator support. I was worried about melting my fans, but it hasn't proved to be an issue so far. |
| The Following User Says Thank You to steverife For This Useful Post: | Mike_ZN6 (07-12-2021) |
#352 | |
2013 Series 10 FRS #553
#353 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
WiSh I'd known about this before I ordered a Borla which is enroute now.
#354 |
If you can return I would. If there desgin is still the same it's pretty damn old. Much better UEL designs than borla
#355 |
Drives: 2016 Toyota 86
#356 | |
I ordered STi motor and transmission mounts from RHDJapan on July 12th and they showed up today. So that makes it 9 days total shipped via DHL from Japan. RHDJapan had the best price, too. |
#357 | |
#358 | |
Here you go: https://www.rhdjapan.com/sti-reinfor...right-zc6.html https://www.rhdjapan.com/sti-reinfor...-left-zc6.html https://www.rhdjapan.com/sti-reinfor...mount-zc6.html |
| The Following User Says Thank You to Mike_ZN6 For This Useful Post: | steverife (07-21-2021) |
#359 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
My JDL 4-2-1 Headers showed up today. I have the gaskets and everything needed. Gameplan is to do the following (unfortunately I think I have to wait until next year to get back to back dyno'd):
1. On the same day, when temps have stabilized, run 2x back to back vdyno's in multiple directions w/ Tomei UEL Header + Delicious Tomei UEL Tune and save the data log 2. Using AIM solo/Vbox Sport run some acceleration runs w/ Tomei UEL Header 3. Swap to JDL 4-2-1 EL Header and load Delicious 4-2-1 EL Tune 4. Run 2x back to back vdyno's in multiple directions w/ JDL 4-2-1 EL Header and save data log 5. Using AIM solo/Vbox Sport run some acceleration runs w/ JDL 4-2-1 EL Header So hopefully this will get us an indication of potential power gains/losses, an insight into the data as far as datalogs go, and some real world acceleration to back up any numbers. The tests will be done on the same day, within a few hours of each other on the same tank of gas. Also for those judging the consistency of vdyno's, I just want to say when they are done right they can be ultra consistent and accurate. Like most things, the output is only as good as your input and most people do it wrong imho. Here's an example of two runs, in the opposite direction. Clearly, they can be repeatable when done right.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
| The Following 4 Users Say Thank You to Goingnowherefast For This Useful Post: |
#360 | |
@justinco did a direct comparison with the Revworks UEL and the ACE 350 a while back: https://www.ft86club.com/forums/showthread.php?t=125559 I'm interested to see the real world acceleration difference between the Tomei UEL and the JDL 4-2-1. |
#361 |
I week away from Dyno tune day with Zach at CSG
#362 | |
Drives: Corolla GT
It a very good upgrade. After fitting the trans mount ( the other two were fitted earlier on ) I noticed a slight vibration in the steering wheel at stock idle. But overall very satisfied, the car is a daily anyways .
#363 | |
I already have the Whiteline KDT926 transmission mount insert installed and I did not notice much increase in NVH. The STi unit will be replacing the stock mount and the Whiteline insert. My car is a daily as well, I am hoping the vibration from the STi transmission mount is not too bad. Did you notice any increase in NVH from just the STi engine mounts? |
#364 |
Just added noise from the gearbox mount, no vibrations.
| The Following User Says Thank You to gpvecchi For This Useful Post: | Mike_ZN6 (07-27-2021) |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 03:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
