#253 |
Drives: 2019 Pure Red BRZ with PP
Good stuff. Let me know what you think of cruising in 6th gear. Do you feel like you have enough power to pass people without downshifting to 5th?
#254 |
Señor Member
Personally I would downshift but I can try 6th and see. What sort of speed range? At 60mph I can't imagine it being an issue. At 50mph I don't think it would be very happy.
1974 TA22 Celica
2013 86 GT |
#255 |
Good Job Subaru!
Drives: Green '17 BRZ Sport-Tech MT
Hey everyone, hope everyone has been enjoying the last bits of summer before it cools off!
I got a better mount for my DSLR, so I wanted to do a little redux of my header video. Has a little more variety in terms of driving situations as well.
| The Following 7 Users Say Thank You to JBezugs For This Useful Post: | dillanp86 (09-21-2019), jflogerzi (09-22-2019), new2subaru (09-21-2019), PulsarBeeerz (09-21-2019), Sefuthun (09-21-2019), weederr33 (10-18-2019), x1UP (06-09-2020) |
#256 |
Good Job Subaru!
Gonna bump this up to the top as I see many more people are running this header out in the wild! How are y'all enjoying it? I was planning a local dyno day earlier this year to compare the gains vs a stock vehicle on the same dyno/same day to have more data for everyone, but due to COVID that obviously couldn't happen.
I still wholeheartedly recommend this header if you're looking for an EL option. My car is still sounding and driving awesome. Hope everyone is staying safe!
#257 |
Drives: '14 FRS TT5
I don't recall if I posted my dyno numbers after I went to E85, but here are my numbers.
You'll probably say, "these look low!" and "there's no comparison!", which are both accurate statements. But the one constant here is that these dyno runs were conducted in compliance with NASA's dyno testing procedures, which usually read low. ![]() Also, the only sounds you need are at full throttle
Follow my NASA TT5 build here: JHill Motorsports
#258 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#259 |
Good Job Subaru!
I also have the same G spot on my dyno run That’s where vtak kicks in.
| The Following User Says Thank You to JBezugs For This Useful Post: | solidONE (06-09-2020) |
#260 | |
"looking at the torque cure, you packin some long tubes" know what I'm sayn'? ![]() Edit: *crickets*
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 06-09-2020 at 06:32 PM. |
#261 |
Just do it. Beside the ace350's these are fantastic headers. Love them with my boosted twin. And they are cheaper to boot than the ace headers
2013 Series 10 FRS #553
#262 |
Drives: Subaru BRZ
Nevermind the numbers, with ACE headers peak hp is usually around 7,400 rpm and the tq stays flat until around 7,000 rpm (my dyno sheet). Can JDL achieve that, or are you limited by class rules and had to detune at higher rpms?
| The Following User Says Thank You to Code Monkey For This Useful Post: | solidONE (06-12-2020) |
#263 | |
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 06-12-2020 at 12:52 AM. |
| The Following User Says Thank You to solidONE For This Useful Post: | Code Monkey (06-12-2020) |
#265 |
Here is my Dyno pull with Zach at csg
https://www.instagram.com/p/B8sJ1XDn...d=ty42p88y5tfo https://www.instagram.com/p/B8sOU-0n...d=klqnb0pf9upg Sprintex 210 +69mm pulley IC, flex fuel JDL 4-2-1, stock op/fp with extra ultra vibrant resonator and mxp sp exhaust Sent from my GM1915 using Tapatalk
#266 |
Drives: 86
Jeez @TMF when you went into that turn going 125MPH, I just about had a heart attack vicariously. What brakes are you using?
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 03:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
