#15 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
The car shouldn't be raspy since you are still running one Cat and stock mufflers which do ALOT to quiet down the exhaust note.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#16 |
TRACKBREAD
Same here. It was very quiet with just a catless header, so check for leaks.
It wasn't until I got a high flow cat frontpipe and overpipe that it turned a bit raspy. Is it raspier than this? |
#17 | |
Somethings wrong, definitely wrong because I had 0 rasp or drone on the stock headerback, and with an axleback and catless header I still have non rasp or drone: 1) Make sure you have a tune OFT or the like, because otherwise you'll get a loud unnecessary cold start, also you're throwing away your money and not really killing the torque dip without it 2) You probably have an exhaust leak, double check your install, specifically the over-pipe to header connection. Using grimmspeed gaskets and high temp RTV got rid of any leaks for me. Also torque them down properly with a torque wrench afterwards, should be around 26-30 ftlbs
| Catless frontpipe and Rasp | Raj | Engine, Exhaust, Transmission | 4 | 12-15-2017 04:00 PM |
| How much rasp will a catless front pipe give me? | appa234 | Engine, Exhaust, Transmission | 7 | 06-19-2017 03:26 PM |
| Rasp help??? | Gshoxx | Engine, Exhaust, Transmission | 3 | 05-01-2014 02:20 AM |
| Running catless, rasp and smell | pgeist | Engine, Exhaust, Transmission | 41 | 04-21-2014 08:26 AM |
| Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 08:33 PM |
