#15 |
Drives: 2017 Subaru BRZ Limited PP
'17 has a hill start assist but it's a major PITA. Just do it on your own: come to a stop on the hill and hold the foot brake, then pull the manual parking brake up. When you're ready to go, give it some gas, start to release the clutch and slowly let the hand brake down as the clutch bites. Eventually on smaller hills you won't need it, but on steep hills it's a great way to save your clutch. Worked like on charm on my 240Z in San Francisco...
#16 |
Drives: '13 Whiteout
You just need to keep practicing. You need to be quick with your feet and and have a good sense of the clutch sensitivity
#17 |
Rust bucket enthusiast
As said by maroon, clutch only starts will build this skillset. To take off on an incline, you let out to near the friction point and add more gas than is needed. Yes, you slip the clutch a bit, but how often are you stopping and starting in the middle of Kilimanjaro? Just keep at it
all good things take time, failures, and effort
#19 |
Drives: 2018 BRZ TS 244/500
I practiced just now about 10 rounds on a two mile street. Somewhat jerking is reduced.
Steps I followed for changing gears: 1st to 2nd release clutch quickly and hold at biting (friction) point for a second (1,000 RPM drop), apply little gas, and release all the way out - same process for all other gears. What I was doing I think wrong by not applying little gas while releasing. I was thought to apply gas after releasing clutch all the way out. Releasing clutch slowly drops RPM very fast, by releasing clutch faster to biting point helps a lot. I think within a month I should be able to drive smoothly. Am I right or wrong, comments please. |
#20 | |
Drives: 2017 Subaru BRZ PP WRB
#21 | |
How do I shift?
Drives: '13 GBS BRZ
For now, focus on not stalling and getting used to changing gear and learning the muscle memory stuff. The smoothness of shifting will come later.
#22 |
I watched this video and drove again as per Robbie - Watch from 10:38, it wasn't smooth. He just releases smoothly without even stopping at biting point. I am confused.
[ame]https://www.youtube.com/watch?v=12GaIurTccc[/ame] |
#23 | |
Drives: 2014 BRZ Limited
The report from U.S. News and World Report show only 18 percent of U.S. drivers know how to operate a stick shift. It says that because of advancements in automatic transmissions and fuel economy, only about 5 percent of vehicles sold in the U.S. today come with a stick shift. That’s down from 25 percent of cars in 1987.https://washington.cbslocal.com/2016...-drive-manual/ |
#24 | ||
The Dictater
Drives: '13 Red Scion FRS
https://cars.usnews.com/cars-trucks/...s-disappearing Quote:
#25 |
Drives: 2017 BRZ
Heck... I still stall it reversing in to the garage sometimes, and I've only owned one auto (for ~4 years) since '94 when I got my license finally. Prior to getting the license I would drive the tiny RWD Toyota pickup we had around the parking lot, just practicing starts.
It takes practice. I find being able to hear things helps me so I usually turn the music off now when I'm backing into the garage. And the tip about keeping your heel on the floor works, not because of friction, but because it isolates the large muscle groups (which don't have much finesse) and you only use small muscle groups (which do).
#26 | |
#27 | |
The Dictater
You have a good start, try reducing the amount of slippage and focus on getting your timing right. FYI, I still have bad shifts sometimes (usually at least 1 per drive) and I've been driving stick for 9 years now. I also need to slip clutch into gear occasionally if something surprises me mid shift requiring spending some time in neutral. Car's still running so it's fine on an occasional basis imo. |
#28 |
The Dictater
| Engine Stalled While In Motion, Won't Fire Up | Borchert97 | Issues | Warranty | Recalls / TSB | 29 | 09-05-2017 08:37 PM |
| Stalled while driving | KDad2 | Issues | Warranty | Recalls / TSB | 18 | 05-23-2016 02:30 PM |
| Learning about cars. | Zoh | BRZ First-Gen (2012+) -- General Topics | 66 | 01-17-2015 03:49 PM |
| POST YOUR 1/4 MILE TIMES Quarter mile times | NYCsubaruBRZ | Tracking / Autocross / HPDE / Drifting | 1 | 02-04-2014 07:59 AM |
| Forum seems to have stalled... | Dimman | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 07-23-2010 06:08 AM |
