Old 09-07-2018, 04:26 PM   #15
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Originally Posted by mav1178 View Post
... or just get longer wheel studs and open-ended lug nuts to use with your spacers.
If installing studs is too much work for what you want to do, just get new wheels.
Not a bad idea, but the lack of tools for the job makes me not want to bother. Every time so far something's been missing for what I need and I have to go out and get it... Maybe it's worth going the easy route this time. Who knows.
Is the issue just on the 20mm spacers or both?
I cut 10 studs in under an hour with a really dull old hacksaw. Cleaned up the tips with a file. I thread a nut onto the stud, cut it, unthread the nut which helps "clean up" the threads, and file the end carefully.
Replacing the studs is not that complicated. I did my front ones in about an hour. The rear takes a bit longer.
Spacers are a compromise for sure. Getting perfect width and offset wheels would be ideal. Sadly, the wheels I wanted only came in high (42 & 45) offsets. I have 5mm, 10mm, 12mm, and 25mm spacers to mess with.
If a hacksaw gets it done in that much time it might be worth looking into it. As of right now it's either that or new wheels. As mentioned, I'd consider replacing them but not sure I wanna go through the trouble.
carsebuco is offline   Reply With Quote
Old 09-07-2018, 04:57 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Did the 25mm spacers cover the stock studs?
Edit: This guy is running 17x8 +15. I think they look amazing! If the 25mm clears, you could get some for the front too. Essentially you would have +17 wheels, 2mm sunk in compared to the link here: https://www.ft86club.com/forums/show...r+557+supercut
I LIKE TIRES!
Old 09-08-2018, 04:09 PM   #17
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
This is with the 25mm spacers. It clears it just right, but this is how much it pokes...
All I can think of is to max out the camber up front with some camber bolts to bring the top back in.. But is it gonna be enough? Hmm...
The Following User Says Thank You to carsebuco For This Useful Post:
Leonardo (09-08-2018)
Old 09-08-2018, 04:58 PM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It will be enough.
I LIKE TIRES!
carsebuco (09-08-2018)
Old 09-15-2018, 09:21 PM   #19
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
It will be enough.
Installed everything today, including camber bolts. Got - 2.3 up front and - 2.1 out back on stock LCA
She's so much prettier now <3
Leonardo (09-15-2018)
Old 09-15-2018, 11:37 PM   #20
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Your car Looks Fantastic!!
I LIKE TIRES!
carsebuco (09-15-2018)
OEM STI wheels + Spacers spicyricecake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-14-2016 01:17 PM
Do spacers fit OEM Wheels ? Wil Scion FR-S / Toyota 86 GT86 General Forum 3 09-19-2015 11:33 PM
FS: OEM BRZ Wheels & 20/25mm Spacers idanvan Wheels and Tires 13 09-05-2014 01:50 PM
Spacers on OEM wheels? BRZlimited BRZ First-Gen (2012+) -- General Topics 13 04-11-2014 08:47 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 12:49 PM
