#15 |
Drives: FRS
| The Following 2 Users Say Thank You to RallySport For This Useful Post: | new2subaru (09-01-2018), Tcoat (09-01-2018) |
#16 |
6/22/12-2/6/24
This thread has been derailed to be about boobs .. haha .. I guess what thread technically wouldn't if it has the chance ..
Also my girl is a bit shy and we should keep our eyes on the road right? :P but I'll probably swap out the shock and struts to the newer set if my current one goes bad
#17 |
I am amazed at the number of people that have drove with the different suspensions under such controlled conditions that they can tell the difference. The changes are minuscule between all the models yet appear to have massive changes when measured on the titcur scale.
#18 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (09-02-2018) |
#19 |
Drives: 2013 Scion FRS 6-speed
#21 |
Drives: 2013 FR-S Series 10
Yes. The ride is much more compliant. The OEMs also add a fatter rear sway bar ( a whole whopping +1mm) to counteract the slight increase in body roll in the corners too.
| The Following User Says Thank You to Decep For This Useful Post: | FRS13_ (09-10-2018) |
#22 | |
Shocks were the same between FRS and BRZ, springs were different.
Fairly noticeable step up in ride quality with the 2017+ shocks. The 2013s were a little rough especially, and I think 2015-2016 are OKAY. Quote:
![]() With our springs, certain roads do feel better/smoother while some types of roads will feel a little bit worse. With 2017+ shocks again it's a little better. - Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | new2subaru (09-10-2018), pumice (09-22-2018) |
#23 | ||
Sent from my SM-G892A using Tapatalk |
#24 |
#25 | |
| Wheel Question on Stock Shocks | FewTooManyBeers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-25-2018 03:04 AM |
| OEM shocks going out? | brazy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 02-09-2018 12:07 PM |
| WTB: Shocks | ThucP | Canada Classifieds | 0 | 08-08-2017 09:47 PM |
| On lowering springs for and stock shocks, time for new shocks... | Basket Case | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-16-2015 09:31 AM |
| What shocks | _F-R-S_ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-31-2012 03:18 PM |
