Old 02-28-2019, 04:47 PM   #43
strat61caster
strat61caster's Avatar
Originally Posted by Tbor View Post
Would this same issue cause my clutch to squeak when pressing in and releasing? I havent noticed any performance issues, but when sitting in neutral I can easy replicate it and hear it squeaking when pushing in and releasing.
Could be the clutch fork lube drying out and needing to be regreased, if you can replicate the noise with the engine off it's that and the bearing doesn't need to be replaced just yet. The bearing going bad sounds more like a squealing, metal on metal not being happy while the clutch fork is a 'groaning' or creaking sound.
Fork Lube:
https://www.ft86club.com/forums/show...4&postcount=23
http://www.ft86club.com/forums/showthread.php?t=56882
Throwout bearing dying
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Tbor (03-01-2019), Tcoat (02-28-2019)
Old 02-28-2019, 04:54 PM   #44
Is it a short "squeak" just when the pedal is moving or more like a prolonged "squeal" that you can change by changing the pressure in the pedal? There are a couple of things it could be. If just a squeak when the pedal is moving it is probably a simple matter of lubing the fork. If a squeal then get it fixed soon before it blows and mangles your whole clutch.
EDIT: Strat's post wasn't there when I first read the question. Now I look silly by saying almost exactly the same thing.
strat61caster (02-28-2019)
Old 03-01-2019, 09:39 AM   #45
Tbor
Drives: Firestorm FR-S
Originally Posted by chipmunk View Post
I'm afraid the symptoms do sound like it. Under 36,000 miles/3 year warranty, this will be covered. But if you're past that and don't want to spend a lot of $$, then see if you have any mechanically inclined friends willing to spare a weekend for you.
I was afraid of this. Im under 36k, but i got my car in aug of 2013. What would happen if this failed? Clutch go out?
Tbor is offline   Reply With Quote
Old 03-01-2019, 09:48 AM   #46
Tbor
Fork Lube:
After watching the videos, im pretty confident the fork just needs some lube. Thank god. Thanks for pointing this out. Thanks @Tcoat for the same info! Really made my day.
The Following User Says Thank You to Tbor For This Useful Post:
Tcoat (03-01-2019)
Old 03-01-2019, 10:32 AM   #47
If it fails it takes out the plate, flywheel, snout and just about everything else involved in the clutch.
Don't leave to too long like this idiot did!
Tbor (03-01-2019)
Old 03-01-2019, 10:58 AM   #48
chipmunk
Drives: _
I'm amazed how you managed less than 36k in almost 6 years!
Even if you're under 36k, you're still out of 3 year warranty. But again, depends on how nice your dealership folks are. Subaru's customer service is eons better than anything I have had to deal with, so fingers crossed!
chipmunk is offline   Reply With Quote
Old 03-01-2019, 02:11 PM   #49
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
hey watch it, that idiot is a legend 'round here
HKz is offline   Reply With Quote
Old 03-02-2019, 12:28 AM   #50
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
Is there a date, vin or year range for this issue? I've called Subaru Canada and they keep informing me that there are no TSB or Recalls for my vehicle of any kind...
Made multiple calls, spoken to multiple reps and same answer based on my VIN. i have a 2014 Manual Transmission BRZ
jbsali is offline   Reply With Quote
Old 03-02-2019, 10:35 PM   #51
chipmunk
Drives: _
A TSB for throw-out bearing? Never heard of one. There is an updated part & updated grease, but no TSB to make knowledge.
Old 03-03-2019, 12:52 AM   #52
TSBs will not show up with a VIN search like a recall since they are just a technical document on how to fix a problem for the techs not a a notice of an issue to the owner.
Here is the BRZ one
This is for Scion/Toyota
Old 03-03-2019, 12:53 AM   #53
Here are the TSBs we have gathered so far.
http://www.ft86club.com/forums/showthread.php?t=21868
Old 03-03-2019, 10:05 PM   #54
SR5
SR5's Avatar
Drives: Raven
Smile noise while depressed
Mine has been making noise for a while (2013 FRS)
going to get
Toyota New part: SU003-07349
Toyota Old part: SU003-00802
& probably the snout wear item SU00303853
(used to be part of the whole trans case on older subies)
[ame="https://www.youtube.com/watch?v=DIlCxj3-LhU"]https://www.youtube.com/watch?v=DIlCxj3-LhU[/ame]
The bearing is a wear item. I think it deserves more attention
it turns more rpm than any wheel bearing would
while taking on the vibration cause nothing is balanced! except maybe the crank.
And also, it's under pressure about 1/3 ton of force when applied
Everytime we startup , we press on this.
That reminds me, shouldn't there be about .100"-to.200" (in general
airspace between the TOB & Pressure Plate fingers?
With all of the Clutch/Fork combo issues, creeping,
heat, etc, I wonder if companies offering aftermarket
clutches/forks take that clearance into consideration?
something smelly, and you still have crickets..
SR5 is offline   Reply With Quote
Old 03-04-2019, 10:42 AM   #55
86league
Drives: '13 BRZ Limited
Other companies can make throw out bearings that last for >100k miles - hell I've owned 3 manual vehicles that went 80k + over about 8 years each. All of them were traded without needing to touch the clutch/TOB. My driving hasn't changed that much and the BRZ TOB failed with 35k in about 4 years. The clutch friction disc looked like it could have gone another 70k easy.
Subaru (or their supplier) just dropped the ball on this particular part.
86league is offline   Reply With Quote
The Following 2 Users Say Thank You to 86league For This Useful Post:
chipmunk (03-04-2019), Tcoat (03-04-2019)
Old 09-16-2019, 01:37 PM   #56
vladniko86
vladniko86's Avatar
Drives: FRS
Here is the BRZ one
Not to resssurect an old thread, I have a 2013 frs with 68k miles. Can I put in the subaru throwout bearing in to fix my squeak? I've tried lubing the components already
vladniko86 is offline   Reply With Quote
Throw out bearing comparison old vs new Trueweltall Engine, Exhaust, Transmission 59 07-22-2022 12:36 AM
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 06:32 PM
Throw out bearing Hyp Northern California 26 03-14-2017 12:42 AM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 11:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 05:45 AM
