Old 08-20-2018, 11:18 PM   #1
Sriracha
Red Ranger
Sriracha's Avatar
Drives: 2013 Scion FRS - Sriracha
Sriracha 86 Turbo Street Build
Alright, everyone, the time is finally here that my build thread is officially kicking off! I have a lot of parts coming in now that I've put a couple thousand miles on the car to really get a feel for what I need to adjust to better suit my driving style.
**Quick disclaimer**
By now you might be asking "Sriracha, you have no turbo parts listed yet? How is this a turbo build?"
The simple answer is there is a lot to turbocharging an N/A car, and even more to doubling the stock WHP numbers. This is something I know first hand and as such like to build for the power I want to make, not around the power by fixing broken parts once it's being made. This makes for a much better experience and a much more fun, reliable and safe(ish) car. As such, the first few months will be supporting mods. After that, the fun will be had. If you don't agree with my methods ( or madness ) feel free to check back around winter so you can read this log backward and pretend that's where I started.
Before we start here is a quick itinerary of what is currently on order for this week:
- Enkei TSP-5 17x9 - arriving 8/22
- Continental ExtremeContact's in 245/40/17 - hopefully also 8/22
- ACT HD Clutch with 11.8lb flywheel - still waiting on tracking info from ft86 speed factory
- Dezod motorsports 2.5 catback - Chris is a little swarmed right now so hopefully within the next two weeks.
First things first ( 8/20/18 ): Tein Street Basis Z Coil Overs
One of the big things I noticed a couple hundred miles in was a bit of body roll at speed on long gradual turns / when attempting to hold a line while linking turns.
Before swapping swaybars, I thought I would try lowering the car some on a pair of performance coil overs to see if that was all it needed. Turns out it was just enough for me as of now for it seems to have fixed the issue and it is much more pleasurable to turn now. Not to mention I gained a decent amount of speed on corner entry/exit while being able to hold an ideal line much easier. The car just feels like it's stuck to the road especially at low to mid speeds, a wonderful unknown feeling for anyone knowing my automotive background. It seems pretty hard to upset the balance of these chassis so far, can't wait to see how the larger stickier tires compliment this. Ride quality is nearly stock ( little harsher on the occasional bump ) but besides that pretty smooth. Ended up setting them at 1.2" from the base of the shock, a -0.4" difference from the recommended 1.6" for now while they settle, will readjust when new wheels are put on. Total drop is close to 2" ( high 1's ) from fender to wheel.
Heres a few pics of the end result on stock wheels.
Coming next my wheels should be here Wednesday ( 8/22/18 ), will post another update when those come in ( and yes I will try to remember to take before pictures this time ). Following that hoping to swap the clutch/fw out this weekend.
If you made it this far stayed tuned guys!
Sriracha is offline   Reply With Quote
Old 09-03-2018, 04:59 PM   #2
Sriracha
Red Ranger
Sriracha's Avatar
Been a little busy but finally got around to posting. A LOT of things have happened in the last couple days.
-Finally got my wheels on ( Enkei TSP-5 17x9 wrapped with 245/40/17 Continental Extreme Contacts ).
-Installed the ACT HD clutch and LW flywheel kit ( 11.8lb flywheel ).
*Install and review coming soon now that I have about 1k on it, second to last pic is how many drinks it took a buddy and I to install.
-Lowered the car another 0.2" on all four corners now that the coil overs have settled ( total drop of 2" now ).
-Got the car aligned and set up with a slight amount of toe out and 2.5 degrees of camber in the rear.
- Still waiting on my Dezod catback, Chris said it should be done and shipped the day after Labor day.
- Also finally got a mount for my license plate.
- Also started an S13 Silvia and NA Miata barn build
More updates to come, stay tuned guys.
There's a reason no one asks me if I love them more than my car ...
Old 10-01-2018, 10:20 PM   #3
Sriracha
Red Ranger
Sriracha's Avatar
Alright, it's been a bit since the last update, work's been a bit hectic.
FINALLY got the exhaust in after a little over a month, gotta say the fitment is on point and the sound is just what I was looking for. Here are some pictures.
Up next ( coming in tomorrow 10/2 ) are my new brakes, rotors and dot 5 fluids.
Turns out heel-toeing all the time has been whats giving my clutch a weird feeling. It's been transferring enough heat over between the two to overheat the current solution causing an inconsistent engagement and pulsation after a few hot laps ( or heavy stop and go ).
Below are pics of new exhaust setup and me boiling my brake fluid on track.
The Following 2 Users Say Thank You to Sriracha For This Useful Post:
ATL BRZ (01-01-2019), JeremyR (10-02-2018)
Old 11-23-2018, 10:53 AM   #4
Sriracha
Red Ranger
Sriracha's Avatar
TUUUURRRBOOOO
Alright guys BIG NEWS in a quick phone update, not at my computer as I'm on travel right now for the holidays and finally have a minute to update my build log.
TURBO KIT IS OTW!!
Spoke with Jesse at JDL and got a deal I couldn't pass up on the kit exactly how I wanted it.
Ended up going with:
- UEL manifold
- GT2860RS
- 3 bar map
- 2.5" flanges and piping for the hot side
- 2.5" resonated and catted over pipe front pipe combo
- Thermal black coated hot side
- Ceramic Red coated cold side
- Cherokee black wrinkle painted intercooler upgrade
- Omni 3 bar map sensor
- JDL bumper bar
- and the standard charge pipe routing
Also I got drilled slotted rotors with ceramic pads but that's not nearly as cool as this...
More updates and hopefully pictures to come!
The Following User Says Thank You to Sriracha For This Useful Post:
Old 01-01-2019, 02:20 AM   #5
Sriracha
Red Ranger
Sriracha's Avatar
Turbo is installed and tuned!! Took me a weekend to get it all said and done but the pull makes it all worth it. Car should've come from the factory like this!!
If you guys wanna see my progress from here on out please check out my car insta where I document everything now at "Sriracha_86".
It's a lot more convenient for me and has wayyy more pics.
DarkPira7e (01-01-2019)
Old 01-01-2019, 09:46 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As I wrote there, awesome work! Hopefully you'll share what it made! It'd be great to see a couple videos of it driving, too. Love this build!
Old 01-01-2019, 10:26 AM   #7
Lantanafrs2
Drives: 2013 frs red
Very nice. I'm gonna need f.i. down the road myself
Old 01-06-2019, 08:55 PM   #8
Sriracha
Red Ranger
Sriracha's Avatar
Ayee thanks for the support man! I have a couple more driving videos I will post soon enough! If youre interested I can DM you a vid or two of it driving before they go up on the page 👍. Also my dyno numbers will come out once I can put a track time down with them haha
DarkPira7e (01-06-2019)
Old 01-06-2019, 08:56 PM   #9
Sriracha
Red Ranger
Sriracha's Avatar
Thanks man! And I cannot recommend it enough, totally changes the car. This thing is crazy, reminds me of a baby Corvette 😂
Lantanafrs2 (01-06-2019)
RCE Street to RallyX BRZ Racecomp Engineering Member's Car Journals 96 06-10-2020 05:15 PM
MyNameIsKeh's Street Build MyNameIsKeh Member's Car Journals 2 10-01-2018 01:38 PM
Racer 713's DD Street/Track build racer713 Member's Car Journals 6 08-11-2018 11:04 AM
Street/Rally Build z3ro Member's Car Journals 3 06-07-2014 07:21 AM
C-Street BRZ 192 Build Info Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-26-2014 11:12 AM
