#197 |
Drives: 2013 FR-S Series 10
I just adjusted my rebound a bit firmer today, front 10 clicks and rear 8 clicks and surprisingly it seems to ride better. I had kind of gotten annoyed with certain floaty feeling on certain undulations during my commute. Tightening up the rebound made it go away. I don't remember what setting i had before but it was whatever was in the RCE settings instructions for street use.
Also got rid of the floaty feeling i had been getting every once in a while on hard turns.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| The Following User Says Thank You to Decep For This Useful Post: | Racecomp Engineering (08-17-2020) |
#198 |
Drives: Black FRS
Finally installed mine with 7kg Swift Springs. Got a basic alignment so it's not dialed in to where I want the alignment to be but it already rides much better than the B8 + Tarmac Springs on the recommended street setting. Feels less harsh on the street and feels much more composed while cornering. The only hard part about the install was removing the front camber plates since I used my Raceseng Cascam. The shock nut had locktite on it so it took a bit of force to remove it and the strap wrench method did not work at all to hold the shaft from spinning. Had to put a socket on the top of the rod which was a bit worrying since I didn't know if it could handle the torque before breaking but it held. The torx bolt on the camber plate was also hard to remove and I almost stripped one trying to remove them.
| The Following 2 Users Say Thank You to Butterballz For This Useful Post: | cueball89 (08-22-2020), Racecomp Engineering (08-22-2020) |
#199 | |
Drives: Toyota 86
#200 |
Drives: Black FRS
KW instructions say 26ftlb for the front m12x1.25 nut but I couldn't get it to torque with a crowsfoot wrench and didn't want to risk snapping the top of the shaft. I just gave it a decent snug by hand. The nut I used kinda screwed in a bit tightly since there was some leftover loctite on the threads so it's been holding so far. It's 15ftlb for the rear shocks but since I used the vorshlag top mounts, I couldn't use two nuts to lock them together so I put a bit of loctite and torqued it to 15ftlb.
#201 |
We'll add me to the list. Gonna order some tomorrow. Can't wait to get them installed
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Racecomp Engineering (09-08-2020) |
#202 |
Drives: 2014 BRZ, 2018 Caymen s
Hey guys, anyone order these and not receive them yet? I ordered mine in July and its still in Germany - Wondering if anyone else has had that experince or just my order?
#203 | |
Our apologies but we'll make good on it, we always do. Myles Williams RCE
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#204 |
Drives: 2019 BRZ / E36 325is
![]() just got my ss-1 in today and i went ahead and installed swift 7k rear along with Raceseng 1inch shock tops. will install before next track day for buttonwillow before the next coming week. very excited to try these out and compare vs my current cusco setup. thanks myles for the help and getting these out to me in a timely manner and answering all of my questions!
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu |
| The Following 4 Users Say Thank You to ayoshioka1 For This Useful Post: | Mike_ZN6 (10-06-2020), pinoy_dorifto (10-07-2020), Racecomp Engineering (10-07-2020), TylerLieberman (10-07-2020) |
#205 | |
Myles Williams RCE
Website
#206 | |
Give me some feedback on the 7k rear setup. Myles
Website
#207 |
Will do, had some issues with the raceseng top mounts so i scrapped those and used oe mounts. should be able to finalize ride height and get an alignment sometime next week. car already feels a lot better in terms of ride quality and can definitely feel increase in compression stroke. car does not feel harsh and does not crash over bumps like my previous setup. This should translate to more grip on track hopefully. Have street rebound set to 12/14 clicks which seems to be a good sweet spot.
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu Last edited by ayoshioka1; 10-09-2020 at 12:53 PM. |
| The Following 3 Users Say Thank You to ayoshioka1 For This Useful Post: |
#208 | |
Getting them installed tomorrow and very excited about that. |
| The Following User Says Thank You to jpixel For This Useful Post: | Racecomp Engineering (10-13-2020) |
#209 |
Got the car aligned yesterday. Was only able to max out the camber to 3.1 in the front with oe crash bolts maxed out at the knuckle and top hat. From recent tire temp data -3 was a pretty good starting point as it showed about a 10 degree delta from inside to outside. Rears were set to around -2.4 as that too showed good tire temps with a delta of 10 degrees from inside to outside from the previous track day. To keep things consist I have kept the alignment fairly similar to before but added some tiny bit of toe out in the front to help with turn in and slight toe in the rear. Excited to test these out on track this weekend and will follow up with some feedback.
| The Following User Says Thank You to ayoshioka1 For This Useful Post: | Racecomp Engineering (10-13-2020) |
#210 | |
Drives: 2016 Toyota 86
I think that is as much camber as you can get with SS-1 on OEM crash bolts. I have that exact setup and I am very nearly maxed out at -2.7 in the front. |
| SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos | PMok | Northern California | 5 | 02-09-2015 06:26 AM |
| -0.5 for RaceComp Engineering | wrxneffect | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-04-2014 05:21 PM |
| Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 18 | 12-07-2013 11:20 PM |
| Racecomp Engineering | industrial | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 05-02-2013 05:17 PM |
| Racecomp website down? | Mikepage | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 04-22-2013 04:12 PM |
