#43 | |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
https://parts.toyota.com/p/Toyota__/...U00307349.html
NARFALICIOUS
Noob Poster 1988 | 2016 |
| The Following User Says Thank You to NARFALICIOUS For This Useful Post: | Trueweltall (08-02-2018) |
#44 | |
#45 |
Resident Gear Head
All in who's label is on the parts Subaru makes most of the parts, but Toyota makes the driveline. Although strange Subaru has been using the same TOB part number since 1990 in 476 different models
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | Tcoat (08-02-2018) |
#46 |
Subaru doesn't make any of the parts. Their suppliers do.
#47 | |
Not all 2017s have the updated parts, it was switched mid-year. see T-SB-0219-17
NARFALICIOUS
Noob Poster 1988 | 2016 Last edited by NARFALICIOUS; 08-29-2018 at 12:12 PM. |
| The Following User Says Thank You to NARFALICIOUS For This Useful Post: | Tcoat (08-02-2018) |
#48 | |
Drives: 2016 Oceanic, "base" model
| The Following User Says Thank You to MrDinkleman For This Useful Post: | Tcoat (08-02-2018) |
#49 | |
#50 |
Drives: BRZ, STI, GT350R, Supra, 987.2
The unit I cut apart was out of my car, the shop car, with ~13k miles on it. The BRZ is a 2014.
| The Following User Says Thank You to VerusEric For This Useful Post: | Spec C Wannabe (08-05-2018) |
#51 | |
It is a fact of engineering that anything and everything that can be made faster, lighter, cheaper will be until you go a little too far making it faster/cheaper/lighter. Then you start over. Every engineering student has watched the video of the Tacoma Narrows bridge. The TOB assemblies in my older Toyotas never gave me problems. My 1988 truck went 175k miles before the clutch was replaced due to a leaking main seal contaminating the clutch surface. There are no tabs on the bearing. It's just a big fat thrust bearing pressed on to a big fat, cast (forged?) bearing carrier that slides up and down a lightly greased steel tube pressed into the front transmission bearing seal. I've no doubt that someone looked at that and thought, "we can make that assembly faster, cheaper, lighter..." but in the process they also thought, "we'll call it a wear item and give it an expected life of 36 months or 36k miles, whichever occurs first." Same goes for the VVTi and DI systems. My 2011 Yaris had the VVTi and DI. It never had the death rattle (see my thread, 0W-30 oil, in the mechanical maintenance section) nor the crickets in the 140k miles I drove that car until it was totalled in a rear-ender... So, I agree with you that resurrecting old tech is a non-starter. But not because it would "not live up to its rep" but because it would increase the cost of the car to a point not many people would buy one. |
#52 |
My TOB finally went out around 65k miles. Decided to change the clutch too. The clutch doesn’t look bad but man the TOB nuked itself and destroyed one of the clips. I’ll get some pics tomorrow.
2013 Scion FRS Firestorm- Current mods: Gruppe-S UEL Headers w/overpipe, Perrin intake tube w/drop in filter Perrin 3" catback, OFT stage 2 turn
#53 |
A.K.A. Starlord
Drives: 2015 Series.Blue
So I had my bearing replaced at juuussstt under 36,000 miles due to this premature "failure" issue. Unfortunately they replaced it with the same old part number, as this was done just before the TSB was issued. I'm now at 62,000 miles. What are the odds I can talk my way into having it replaced again? Probably slim...
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#54 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Here's a link to a thread I started on this topic. I recently purchased the Exedy OEM replacement FJK1005 kit which appears to come with the revised part. I'm not sure if all of their stock has been revised yet or not so it's worth checking and then buying the part from Toyota/Subaru if you did not get the revision in your kit.
http://www.ft86club.com/forums/showthread.php?t=138893 |
#55 |
Edit: Disregard, the bad TOB and revised appear to both have shared the same type of housings so without seeing the white dot on one of the tabs, there's no way to know if it's truly the revised version. http://www.ft86club.com/forums/showthread.php?t=138893 Last edited by B-R-Z; 02-16-2020 at 03:50 PM. |
#56 |
Drives: S14K
correct. NTN is the manufacturer/supplier for the release bearing.
https://bcabearings.com/catalog/sear...26model%3D9563 |
| Throw out bearing | Hyp | Northern California | 26 | 03-14-2017 12:42 AM |
| Post If You Have Had Your Throw-Out Bearing Go Bad! | Bushhy | Issues | Warranty | Recalls / TSB | 8 | 10-24-2016 06:34 PM |
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 11:21 AM |
| Noisy throw out bearing | jp_r6 | Issues | Warranty | Recalls / TSB | 23 | 08-18-2016 05:45 AM |
| throw out bearing clips... | Shit Luck | Engine, Exhaust, Transmission | 0 | 04-12-2014 07:34 PM |
