Old 07-19-2018, 08:41 PM   #1
ajh88
Drives: 2013 Firestorm FR-S
Tire pressures on track - Falken RT615K+
Headin out to the track this weekend and wanted to know if people running these tires have any thoughts on what kind of cold pressures the Falken RT615K+ like on the road course. I dont have a pyrometer so never an idea of what mine have been getting up to...
Thanks.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 07-19-2018, 09:51 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I would ask who ever is instructing.
Personally I would start at 28 cold. After the first session you should be around 38-40s adjust accordingly
Old 07-20-2018, 01:16 AM   #3
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Thanks.
I run 255/40-17 Falkens on my STX prepped BRZ, they seem to be happy in the low to mid 30's hot. I usually start with cold pressures of about 28psi (I run the fronts 1-2psi higher than the rears). Later sessions the tires usually start to retain some heat and they don't gain quite as much pressure.
I check the pressures in the pits and make sure they're even side to side (usually tracks favor one side or the other). The Falkens seem to be relatively forgiving with pressures though, you have to get them under 25psi or close to 40psi before they really start to get unhappy.
If they aren't making noise, you aren't driving them hard enough. When you get to the limit, they sing.
I really like them for track tires, they're 1-2s slower than an RE71 but they feel good and last.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
wparsons (07-22-2018)
Old 07-20-2018, 10:21 AM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
With my particular setup, I start at ~30psi cold and after a 20 minute session I'm at ~36psi and 145-150 degrees F across the entire face of the tread. I'm not getting the temp at the optimum time though, as it's probably 5 minutes between the last run and by the time I get my car back to my pit area and take the temp with an infrared pyrometer, which itself is only taking surface temps. It's more important to be consistent in your methodology for comparison's sake. I run 225/50-16, so they seem to like a little more pressure than a lower profile tire would.. I've tried dropping them a bit, hot, from 36psi, but the only noticable change was feedback (less).
Keep them singing all the time, not howling.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 07-20-2018, 12:53 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
When I had my RT615s I usually set them to about 35PSI hot and go from there depending on how the car is on the track.
As for what temps cold, you will need a bit of hands on learning to figure that out. Usually I do 30PSI cold and adjust down from there, but as you get more aggressive with driving you'll find you need to start off at lower temps.
-alex
Old 07-20-2018, 04:33 PM   #6
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Without using a pyrometer you are just guessing. Starting at 28psi cold might get you in the ball park but ultimately you need a pyrometer to determine the right setting.
Lincoln Logs is offline   Reply With Quote
Am i choosing the right tire and size (Falken RT615k+ vs Hankook Ventus v12) re-animator Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-28-2018 02:39 PM
Motegi 17x7 with Falken RT615K+ in PA bmacfrs Wheels and Tires 3 02-04-2018 08:11 AM
AX Tire Pressures RMP Tracking / Autocross / HPDE / Drifting 9 12-02-2014 08:19 PM
Tire Pressures mike the snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-21-2014 04:03 PM
