Old 07-30-2012, 05:38 PM   #29
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Definitely getting one
Memphis is offline   Reply With Quote
Old 07-30-2012, 06:01 PM   #30
Memphis
Memphis's Avatar
Originally Posted by michaelahess View Post
This is what I used on my BRZ, works fine:
http://www.ebay.com/itm/130728541504...ht_3134wt_1159
Im looking at getting these.
http://autolumination.com/images/aut...3_12w_r_wm.jpg
They are not cheap but they look to be the brightest out there.
Anyone find any better?
Old 07-30-2012, 06:05 PM   #31
HunterGreene
Hail Magnet
HunterGreene's Avatar
This is the exact same unit. The guy selling them on amazon (refer to my earlier post) sends them out quick. I had the new relay inside of a week.
Old 08-01-2012, 12:26 AM   #32
frs
Drives: frs
can you use them for the rear signal lights?
frs is offline   Reply With Quote
Old 08-01-2012, 03:47 AM   #33
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Yup. I'm not sure what size LED bulb the rears take, but then you can hook the resistors to the two turn signal wires to slow down the flash rate.
Old 08-01-2012, 11:12 PM   #34
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
All four are the same.
michaelahess is offline   Reply With Quote
Old 09-12-2012, 06:38 PM   #35
Goodguy889
Goodguy889's Avatar
Drives: Hyundai genesis 2.0t
So would I need to buy 2 if I do front and back?
Goodguy889 is offline   Reply With Quote
Old 09-12-2012, 08:48 PM   #36
DarrenDriven
NW Region Moderator
I think so... I haven't gone to LED in my rears yet. I imagine that without the proper resistance in the incandescent bulbs you would get speed blinking again.
Old 09-19-2012, 10:29 PM   #37
Zadkiel
Drives: CBS BRZ Limited 6MT
I think those are the Flashbolt 5s right? I bought some off of KI_ZN6 and they're worth every penny. The rears are tricky to get in though. Not enough wire so you have to partially fit the bulb into the housing and then plug it in.
I also have the relay mentioned multiple times in this post and it works like a charm. It's underneath the steering column. You need to pretty much sit upsidedown by the pedals, looking up toward the wheel. From that orientation, it'll be just to the right of the electric motor.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
The Following User Says Thank You to Zadkiel For This Useful Post:
KI_ZN6 (09-19-2012)
Old 09-20-2012, 09:41 AM   #38
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
http://www.v-leds.com/Vehicle-Specif...-p9807550.html
I went with replacing the flasher relay with one designed to eliminate the hyper flash. The only drawback to this method is that it will never hyper flash so you won’t know if you have a bulb out. I am not too worried about it, I figure I will just do a walk around with the flashers on every once and a while.
This was not too hard, except my fat ass and big hands made the job “challenging”. After you pull off the panel under the steering wheel you need to get under the wheel on your back and reach up under the dash to get to the relay. If you are on your back the relay is to the right of the steering column.
It is attached via a clip to a metal mount. You need to get the flasher off the clip or pull the clip out. Once that is done, easier said than done, you just unplug the relay from the harness and plug the new one in. Then swap the clip from the old one to the new one and wedge yourself back under the wheel and stick it back where the old one was.
I suggest you find a small friend with small hands, or even a child, to help. If that is not available then at least get a pair of mechanic gloves to avoid the result below.
jadewbj is offline   Reply With Quote
Old 09-20-2012, 03:05 PM   #39
Zadkiel
I never had to pull any panel. Then again I had to contort myself to get down by the footwell, upside-down, to get to it.
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 04:41 PM
Simple One: Clear Turn Signals Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 37 07-26-2012 03:03 AM
Tinted signals and markers RandomHero Cosmetic Modification (Interior/Exterior/Lighting) 2 07-19-2012 10:37 PM
FRS APR FRONT LIP sidnacious Cosmetic Modification (Interior/Exterior/Lighting) 7 07-06-2012 07:50 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
