#29 | |
Drives: 2015 BRZ
#30 |
Drives: 2014 GT86
Vital: Single set of camberbolts is "worth" aproximately upto -1.5. if one uses camberbolts at both holes, it's possible at stock height to get -2.3 camber total, if lowered, then upto -2.5.
| The Following User Says Thank You to churchx For This Useful Post: | Vital (07-11-2018) |
#31 |
Drives: 2018 BRZ w/ PP - WRB
Don't know if this makes the difference, but I had watched a video where they installed the camber bolt in the lower of the 2 holes, and then moved the lower bolt to the upper bolt position, and this is what I did. Supposedly, this gives you a little more adjustment capability.
| The Following User Says Thank You to Geese1 For This Useful Post: | Vital (07-11-2018) |
#32 | |
Drives: 2017 DGM BRZ PP
| The Following User Says Thank You to Horrid_Funk For This Useful Post: | Geese1 (07-11-2018) |
#33 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Is there a preferred set of alignment specs for a bone stock '14 FRS DD which will get a few track days per year? I will run separate track wheels and rubber.
#34 | |
Senior Misanthrope
![]() edit: you can DD with those settings, too. I DD mine at -3.5/-2.2. |
#35 |
What kind of tread wear do you get on the street with those numbers?
#36 |
Senior Misanthrope
| The Following User Says Thank You to kch For This Useful Post: | strat61caster (07-18-2018) |
#37 | |
Sittin' Sideways
Drives: 2016 Toyota FR-S
-O/D
2016 FR-S, Hot Lava |
#38 |
I would certainly say so! I've been tracking Miata DDs and front-engine Porsche DDs for a long time with -1.75 front and haven't had excessive shoulder wear on street or track tires. The last time I aligned the Miata I went from 5.0 to 6.4 caster, and directional stability increased significantly. The FRS will get it's first alignment under my ownership next week.
#39 |
Drives: 2017 Halo 86
I installed suspension, wheels, tires and it seems to drive perfectly straight-line.... I'm wondering if I should even bother to get an alignment done, have had a car come out of shop worse than when I took it in...
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#40 |
Drives: 2016 Subaru BRZ
Yes, get it checked out.
#41 |
Your car can drive straight and still have a bad alignment.
- Andrew |
| The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post: | churchx (07-23-2018), dhuang (07-23-2018), kch (07-24-2018), strat61caster (07-23-2018), Trueweltall (07-22-2018) |
| Recommendations for alignment in Bay Area | Surj_brz | Northern California | 9 | 06-09-2017 01:26 PM |
| Need alignment spec recommendations | 8RZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 05-10-2017 10:53 PM |
| Alignment recommendations for my setup? | sqd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-19-2016 02:33 PM |
| Alignment shop recommendations? (SEA) | Koa | Northwest | 7 | 02-16-2015 08:18 PM |
| Recommendations for alignment in Socal | anewprelusion | Southern California | 18 | 01-13-2014 03:36 PM |
