Old 06-25-2018, 11:24 AM   #1
redwine
Out of town...Remove DCC Fuse or Battery ?
Hello,
I understand from the Svc Manual,
there's a DCC Fuse (aka Direct Circuit Connection fuse or D/C Cut fuse) which the Factory remove before shipping the vehicle to dealer.
Dealer are suppose to re-install the Fuse to the correct slot prior delivering the vehicle to customer.
The Manual state this is to prevent battery consumption during shipping.
So if you are going out-of-town for like 2/3 weeks,
would it make sense to just remove the DCC Fuse or to remove the Neg Terminal of the battery ?
(I will need to get tooling for the battery...14mm i suppose?)
Anyone know if the DCC Fuse will disable everything (like disconnecting the battery),
or it will only disable selected devices.
Many Thanks
redwine is offline   Reply With Quote
Old 06-25-2018, 11:47 AM   #2
Code Monkey
Drives: Subaru BRZ
I wouldn't worry about the battery going out after 2-3 weeks.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Stang70Fastback (06-25-2018)
Old 06-25-2018, 11:56 AM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It's only 2-3 weeks. Don't worry about it.
If you're going somewhere for 6 months, then maybe start thinking about battery things.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 06-25-2018, 12:30 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
As others have said, that's a short time frame so I'd leave it alone.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 06-25-2018, 01:55 PM   #5
redwine
Thanks Guys
Does that still apply if the battery is 2-3yrs old ?
Also,
if you disable the battery (fuse or remove terminal),
any thought on whether it will reduce or increase the risk of theft (if not park inside private garage).
Regards
Old 06-25-2018, 02:18 PM   #6
extrashaky
Drives: 2014 BRZ Limited
Maybe it depends on the battery. My OEM battery was a turd. Two weeks was about the max you could leave it sitting and be able to count on it starting.
And yes, I'm sure it was the battery. I have a Duracell AGM in it now, and the problem is gone. My engine also used to stumble when I turned the lights on (from the first week I had it). I though it was just a quirk of the car, but that issue has stopped with the new battery as well. It amazes me that Subaru would ship the cars with such a piece of crap in it.
The Following User Says Thank You to extrashaky For This Useful Post:
rvoll (06-25-2018)
Old 06-25-2018, 06:25 PM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
If you are looking for piece of mind, your local parts store likely provides a battery test[most cases it is free] to determine the life cycle on the battery.
3 weeks isn't long enough to drain a good functioning battery. Just make sure you don't leave anything that could draw on the system while you are gone.
Code P2102 after blown fuse on battery terminal Krewmaui Engine, Exhaust, Transmission 1 05-05-2017 11:41 PM
Car Won't Start.. No Lights.. Not a battery or fuse issue.. pleong Scion FR-S / Toyota 86 GT86 General Forum 11 09-23-2015 04:45 PM
Battery Terminal Fuse replaceable? STS-V Scion FR-S / Toyota 86 GT86 General Forum 1 03-14-2014 08:36 PM
Battery Terminal Fuse replaceable? STS-V Electronics | Audio | NAV | Infotainment 0 03-14-2014 08:23 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
