86WORX
Old 06-14-2018, 10:55 AM   #1
DeltaEcho
DeltaEcho's Avatar
Drives: 17BRZ Limited TS
Louder Engine Noise while Driving
Hello fourms,
I wanted to get your opinion on my engine sound this morning I experienced. Please take a listen and wanted your opinion.*
Normally my engine and acceleration is much quieter. Only change was the header wrap was removed in the past week and engine is much louder. Fluids are good and no leaks. My guess is the Headers without the wrap make it louder since there is more exposed radiant heat.
Should I be concerned?*
Only thing I tested was flashing my OFT tunes from current v4.02 to stock. Loud sounds still exist. Video uses v4.02 and keeps engine quieter.*
Did you hear any of these experiences?*
Current performance mods:
OFT v4.02 Stage 2+
Grams Throttle Body
Perrin Cold Air Intake
Perrin Crank/Alternator/Water pulleys
Cusco Oil Cooler
Perrin Radiator Hoses
PLM UEL noncatted headers
SRS overpipe/midpipe reasonated
Perrin Catback Exhaust
https://cloud.tapatalk.com/s/5b227331..._094347024.mp4
Code:
https://youtu.be/Vqhi0h5PulM
Sent from my G8142 using Tapatalk
DeltaEcho is offline   Reply With Quote
Old 06-14-2018, 01:42 PM   #2
humfrz
Originally Posted by DeltaEcho View Post
Hello fourms,
OFT v4.02 Stage 2+
Grams Throttle Body
Cusco Oil Cooler
Code:
I'm not sure what your question is …….. but, I think your answer is partially correct. Unwrapped header is louder because it lets more sound out …..
humfrz
Old 06-14-2018, 07:10 PM   #3
DeltaEcho
DeltaEcho's Avatar
Mods please close fourms.
Found the culprit.
Bad gasket between overpipe and headers
Old 06-14-2018, 08:14 PM   #4
humfrz
Found the culprit.
Bad gasket between overpipe and headersSent from my G8142 using Tapatalk
"Current performance mods:
OFT v4.02 Stage 2+
Grams Throttle Body
Cusco Oil Cooler
Perrin Catback Exhaust"
"For the want of a nail, a horse lost a shoe ….."
humfrz
Ultramaroon (06-15-2018)
Old 06-14-2018, 11:53 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Found the culprit.
Next time if you hear a loud exhaust noise or what sounds like a leak you can confirm it by datalogging with the OFT (as long as your not running e85) and looking for high LTFT numbers (5-10 percent). If you have high long term fuel trims then you likely have intake or exhaust leak.
Suspension or joint noise after driving? vuthatswho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-28-2017 04:17 PM
Rear clunking noise when driving EvoXSwimmer Issues | Warranty | Recalls / TSB 4 07-24-2017 04:03 PM
Tinny noise during normal driving. Kicker18 Issues | Warranty | Recalls / TSB 4 03-17-2017 11:10 AM
Humming noise while driving maylchi Issues | Warranty | Recalls / TSB 9 03-13-2015 02:29 AM
Tapping noise after driving MrAnthonyC Issues | Warranty | Recalls / TSB 2 09-23-2014 02:06 PM
