#99 | |
Drives: LS Swapped Scion FRS = 440HP
I did notice the under hood temperatures were warm, specifically at the fuel rails since they're at the very top, but the addition of the tracspec hood vents keeps the engine bay nice and cool now. Oil pan (and all parts) are listed in detail at the first post of this thread. I routed the cylinders two and four under the headers up the front of the engine and to the coils. Did this with some MSD 32073 cut-to-length LS wires.
| The Following User Says Thank You to spitsnaugle For This Useful Post: | CokeZero (12-07-2018) |
#100 |
Probably the last time its out for the year...
![]() Just got 255/40r17's mounted instead of the 235/40's... they don't really hook any better. Time for slicks and a second set of rims. should note 255's with 17x9 +42 wont fit up front without a spacer. Last edited by spitsnaugle; 12-11-2018 at 11:43 AM. |
#101 |
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
@VR4EVER @spitsnaugle did yall run a batch of clutch master cylinder recesses or did some make it over to @Pure Automotive for sale?
#102 | |
Thanks for the reminder, my location of the MC was slightly higher than OEM causing a slight hard spot in the pedal swing. This higher location was to avoid a stud (the stud only holds harness) from below it. I finished revising the design last night, removing that stud, I'll send it back to my CAD guy this week. |
| The Following 2 Users Say Thank You to spitsnaugle For This Useful Post: | all4spl (12-12-2018), Axis2011KR (12-12-2018) |
#103 | |
Drives: Red BRZ
Sent from my SM-G950U using Tapatalk Last edited by vijay.dy06; 12-12-2018 at 03:53 PM. |
#104 |
Waiting to hear final prices from CNC guy. He has my revised design, asked me for a few more dimensions. (I'm only familiar with 2d cad work, not 3d).
I'm not a site vendor. So I wont be publicly announcing pricing or sales, keep it to PMs or hopefully I'll just produce some batches for PureAutomotive to sell. ![]() PS to all- I've been reorganizing the my posts throughout this thread, trying to consolidate important info into the first post, and putting posts into better order. Hopefully its useful info for folks getting started in their swaps. Last edited by spitsnaugle; 12-16-2018 at 07:44 PM. |
| The Following 2 Users Say Thank You to spitsnaugle For This Useful Post: | Axis2011KR (12-17-2018), Merc (12-16-2018) |
#105 |
Drives: Subaru brz 2013 LS1 swap
Wow first page first post update with the build process, all parts, and electrical is awesome! This Thread has to be one of the best laid out ive seen really helping my build go much smoother. Thanks for the great build thread.
#106 |
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
I must have missed the part about the rear end. Are you using a completely stock diff, a stock diff with different gears, or a swapped diff? I'd consider doing a Ford 8.8 on such a setup.
#107 | |
My next order of changes are:
I formerly had a ford 8.8" in my 240z with 930cv joints, it was overkill. We have the same 8" rear end as Lexus IS300's and Supras. I suspect it'll handle my mid-400whp without too much issue. If I was north of 500hp, I would be worried. Last edited by spitsnaugle; 02-08-2019 at 12:07 PM. |
| The Following User Says Thank You to spitsnaugle For This Useful Post: | frsty_86 (12-20-2018) |
#108 |
Drives: 2015 brz
#109 |
Lowe's: Gorilla Cart, has removable sides.
That one has 1,000lb capacity, another Gorilla Cart model at HomeDepot had 1,200lbs. Super handy to roll around dirt, stone pavers, or an engine. https://www.lowes.com/pd/Gorilla-Car...Cart/999930538 Last edited by spitsnaugle; 06-14-2019 at 02:57 PM. |
#110 |
What was the length approximately on the spark plug wires 2 and 4, also only 2 and 4 around the front? I'm using the cx headers as well but I ceramic coated and wrapped them so pretty tight on a few spots between but should be less heat.
#111 |
No idea, never measured, I put them on the coil, routed them with space, marked the wire at the spark plug location, and cut.
#112 |
master cylinder recess update:
first REVISED model is being cut now.
| Tags |
| cx racing, ls swap, ls2, pure automotive |
| 2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP | ILLSMOQ | Engine Swaps | 172 | 11-24-2022 08:01 PM |
| LS2 swap by KAB Customs with Pure Automotive Motec | Sportsguy83 | Engine Swaps | 254 | 10-17-2018 01:45 PM |
| Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 12:10 PM |
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 05:21 PM |
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 02:03 AM |
