#15 |
The second fan will also kick on if it's too hot, not just when the AC is on. Removing the second fan could lead to overheating at slow speeds on hot days.
| The Following User Says Thank You to wparsons For This Useful Post: | Trust86 (02-22-2019) |
#16 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Does anyone have the weight of the stock shroud/dual fan setup??? can't find it anywhere. Mishimoto makes a claimed lighter setup at 7.5lbs. If it is 5lbs or more lighter than I would pay the $275 for it |
#17 |
Drives: 2017 BRZ
Have you considered moving the alternator to where the AC compressor was and deleting a few pulleys?
#18 | |
Leaving the door open to add my AC back in since it was only 15lbs lost
#19 |
Drives: '15 BRZ RA
The AC delete was one of my first mods after the better wheels & tires. My car was already lighten from the factory, so there wasn't much to remove in other areas like spare wheel or sound deadening material. Yes the weight gain of the delete is not that big, but it also matters where this weight is located. The AC compressor sits quite high in the engine bay. I would never consider to put it back, unless this was my daily driver or I was living in a very warm climate.
#20 | |
| The Following User Says Thank You to SuperTom For This Useful Post: | nikitopo (07-04-2018) |
#21 |
Weight Weenie
Drives: 15 FR-S
The Evap Core is 2.75lbs
#22 |
Weight Weenie
Drives: 15 FR-S
This is what is needed to get it out. It's housed in the black part or the HVAC unit right above the Trans tunnel. It unscrews from the bottom so the whole unit has to come out. I disconnected the electrical ECU's on the passenger side and cut all the tape holding the harness to the dash bar. Peeled it back and took the unit out. I did a lot of research before doing this and it wasn't too horrible. I would do it again, but there's something wrong with me lol
There's an additional 1.75lbs of insulation behind it and some sound deadening on the Trans tunnel that I can get to now. I'll post that weight when it's out. |
#23 | |
Weight Weenie
Drives: 15 FR-S
Tom, I did weigh both the shroud and fans when I had them out. The shroud was 2lbs. I think the fans were right around there too. I'll weigh them again to confirm. |
#24 | |
Bigger thanks for dash removal pic. I am currently working on lightening weight out of the dash bar running across, its 17lbs of heavy steel. Nice to know that there is more weight to lose behind the dash. Between the dash beam, AC condenser, and insulation should I should be able to get 10-15lbs off the car
#25 |
Drives: Black BRZ
Great stuff as usual - very informative. Big thanks for sharing these updates. Is the car getting closer to about 2400 lbs now or is it even lower than that?
#26 | |
Weight Weenie
Drives: 15 FR-S
I struggled with the dash bar for an bit with another guy on the other end. It kept wanting to turn towards the front of the car. It was becoming a royal pain in the ass. Time to walk away for a bit... The design is great. Each side has two pins that the car rests on. You get it there and you're golden. I ended up using a bottle jack under the steering column, l lifted it less than a half inch and the drivers side popped right into place. Then I just had to lift the passenger side into place and bolt it back in. I ended up cutting all of the tape holding the electrical harness in place to makes things easier. A simple job to tie wrap them back on, so it was worth it. I'm chasing unused electrical now and that'll take a while. The HVAC box is 13lbs without the Evap Core. I will be working on replacing that with something else next winter. I'm sure I can lose 8lbs there. Last edited by new2subaru; 02-22-2019 at 12:31 AM. Reason: spelling |
#27 | |
Im at 2375. Messing around in the dash can get me to 2360. After that its all big money for Dry Fenders, hood, roof with minimal loss. I maybe finished for a while after I do the under dash stuff. $$/lb at this point isn't worth it, although all that weight would be off the nose. |
#28 | |
Drives: 2013 frs red
| DIY my version Rear Seat Delete ~$60 Weight Reduction 27.5 lbs | SuperTom | DIY (Do-It-Yourself) Guides | 29 | 10-25-2022 01:45 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 12:38 PM |
| Weight of your brz/frs | NYCsubaruBRZ | NY / NJ / CT / PA | 5 | 02-12-2014 08:11 PM |
| WTB: Berks dual tip muffler delete and cat delete pipe | Black86 | Want-To-Buy Requests | 0 | 09-27-2013 10:31 PM |
| WTB Berk Dual Exit Muffler Delete or Works AB Delete | Admired | Want-To-Buy Requests | 2 | 09-10-2013 05:20 PM |
