#85 | |
Rust bucket enthusiast
**EDIT** There were no clearances or other paperwork unique to this engine included, only paper instructions for their recommend break in and installation procedure
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 12-31-2020 at 09:33 AM. |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | elitegunslinger (12-31-2020) |
#86 | |
Drives: 2014 BRZ Limited
#87 |
Yeah I got them just now
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#88 |
Thanks a ton!
Very interesting, slight variation on the main bearing clearance .0013 seems like they rounded up on the loose side past OEM spec. Rod bearing clearance is basically the same as stage 3. Piston clearance is the same. Also the ring end gaps are the same. I think I have my target clearances for building up my block now; time to power wash the halves and bring it to the machine shop for resurfacing, honing, and some measurements.
| The Following User Says Thank You to elitegunslinger For This Useful Post: | DarkPira7e (12-31-2020) |
#89 |
Identifying as a Member
Drives: 2013 FRS LS1
Sub'd and excited to see this thing come together!
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
| The Following User Says Thank You to Tomm For This Useful Post: | DarkPira7e (01-06-2021) |
#90 |
Me too, trust me. At this point I just value the car moving under its own power, I don't care if it only made 1 WHP over stock. But it really doesn't matter if I put all the turbo stuff on or not, the hard part is getting it all back together and tuned to run again. It's going to be such a vastly different car than I had last driven, I can't wait! Mostly new suspension components, new motor mounts and transmission mounts... it'll be my ideal car.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tomm (01-06-2021) |
#91 | |
My wife and I ended up buying an older 4Runner (2004 V8 Sport) just to have in case one of the other cars was down - this is mostly because I had to do the manifolds on my wife's truck and it was down and out for 4 days. It has turned into her daily but also another project car for me. Back on topic, the entire feel of the car is going to be crazy different - for the best I believe. Also I love the idea of a throwing together a frankenstein turbo kit. So the big question I have is, if you were to start this whole process over again would you have gone a different route?
#92 | |
I agree, I enjoy the process of thinking and planning much more than the average joe. I have my wife's 09 Nissan Sentra ( sold my DD Honda I bought because she isn't going to be driving anymore or any time soon) so that's the beater. At least it has a manual e-brake handle for snow sliding, even if it's FWD automatic, certainly better than snow shoes. If there's one thing this car lacked, it was suspension stiffness (for my preference) compared to my 92 autocross E36 I had before. I like having a stiff car, I don't care about rattles or squeaks, I just want it to communicate. I wanted to wait until most of the suspension parts had warranted upgrading before doing it; now is as good of time as ever. I can't wait to feel the vibration of the motormounts in my steering wheel. What would I do differently? Definitely wouldn't have done the J02 recall. I don't have regrets about trying to make the CXracing kit work; it does function and I would still be using it if not for the motor trauma, but I get the feeling I would've ended up here anyway at some point (and was ready for that). I very much look forward to having components that are in like-new or brand new condition that I can trust for years to come. I will not back off and stay NA, I loved the car NA but I am determined and will not concede. A turbo kit is not complicated and there's no reason why the car shouldn't stay together with a competent tuner setting everything up ( not me)
#93 |
Beginning to get ready to put this bitch back together! I must face the task I've been avoiding... Stripping all the Threebond off of the heads, cams, and everywhere else I find it.
This is going to be a long weekend.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tomm (01-08-2021) |
#94 |
| The Following User Says Thank You to Tomm For This Useful Post: | DarkPira7e (01-08-2021) |
#95 |
Drives: Bone stock
Oh boy!!! Let's man. Can't wait for this ole girl to come back alive.
Sent from my SM-N960U using Tapatalk |
| The Following User Says Thank You to Joveen For This Useful Post: | DarkPira7e (01-08-2021) |
#96 | |
Drives: Crapcan
The real fun part is putting the timing cover back on.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (01-08-2021) |
#97 |
Drives: FRS
Awesome build!! What made you use that turbo??
#98 |
Drives: 2019 Toyota 86 TRD SE
Been lurking on this thread. Really cool build man.
| Tags |
| brz, frs, iag, jdl, turbo |
| Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 06:59 PM |
| Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 08:57 AM |
| Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-26-2015 12:02 AM |
| My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 10:29 PM |
| Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 09:44 AM |
