Old 10-15-2020, 06:52 PM   #71
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Well, I'm impulsive, what can I say. Southbend stage 3 clutch, Verus clutch fork and pivot! Interestingly enough, the clutch itself is an Exedy manufactured product. The pressure plate is just spray painted red, the paint smell was quite pungent when I opened the box, and there was some parts they missed. Not that it matters, just putting that info out there for people who may be hoping for something expertly executed with aesthetics in mind.
I love that break-in instructions are included ON PAPER. No webpage deciphering or hunting.
The clutch fork is much more heavy duty feeling than I had expected. I have absolutely no doubt that this piece could withstand literally anything. The pivot looks nice, bling honestly.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Joveen (10-15-2020), NoHaveMSG (10-15-2020)
Old 11-02-2020, 04:34 PM   #72
DarkPira7e
DarkPira7e's Avatar
Got a wideband put together for me at VEMS with the Bosche 4.9LSU sensor. Unsure what I'm going to add as secondary (it's a dual display) but I'll figure it out.
Old 11-07-2020, 02:43 PM   #73
DarkPira7e
DarkPira7e's Avatar
Decided to measure the turbo, since nobody seems to run or have data on it.
Just to rehash- it's a Boostlab BL5858 journal bearing turbo.
anticubus (11-07-2020), Joveen (11-07-2020)
Old 11-07-2020, 02:46 PM   #74
Joveen
Joveen's Avatar
Drives: Bone stock
That thing is beautiful
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following 2 Users Say Thank You to Joveen For This Useful Post:
anticubus (11-07-2020), DarkPira7e (11-07-2020)
Old 11-08-2020, 05:36 PM   #75
DarkPira7e
DarkPira7e's Avatar
Got my wideband installed today!
Old 11-10-2020, 09:35 AM   #76
DarkPira7e
DarkPira7e's Avatar
Well, I made a decision to end my suffering. I'm ditching the CXracing manifold and bought the JDL EL manifold/downpipe setup. Not recirculating the wastegate dump back into the exhaust, if I need to be quiet I will just stay out of boost.
The build looks like this now-
Engine/Fuel/Electronics-
IAG Stage 1 Shortblock 10:1CR
Refreshed Stock Heads w/ Kelford 62lb Springs
ID1050x Injectors
ECUtek W/ Racerom
VEMS Wideband Gauge
Drivetrain -
Southbend Stage 3 Daily Clutch
Fidanza Lightweight Flywheel
Velox Carbon fiber Driveshaft
STI Transmission Mount
Torque Solutions Engine Mounts
Suspension/Wheels/Brakes -
Apex ARC-8 17x9
Nitto NT555R 245/45
Stock 2017 Subaru BRZ Performance Pack Sachs Struts
Centric Blank Rotors
TRD Brake Pads
Eibach Pro-Kit Springs
STI Strut Mounts
Whiteline Front Endlinks
Whiteline KDT925 Differential Outrigger Inserts
Whiteline KDT922 Subframe Bushings
Energy Suspension Swaybar Bushings
MTEC Transmission Shifter Detent Springs
Turbo/Exhaust-
JDL Front Mount Intercooler
Turbosmart Raceport BOV
JDL EL T3 Manifold W/ External Turbosmart UltraGate 38mm Wastegate (open dump)
Boostlab BL5858 Turbo
JDL 3" Downpipe
JDL 2.5" Overpipe / Dual Resonated Frontpipe
FT86SpeedFactory x Remark 3" Quad Tip Catback Exhaust
Other Misc-
Radium Engineering PCV Oil Catch Can VTA
Radium Engineering Fuel Rail
Verus DI ECU Bracket
ATI Vent Gauge Pod
A/C Delete
Mishimoto Slim Shroud w/ 1150CFM Fans
Custom Suede Wrapped Center Console
eBay Center Armrest
JDM Black traction Control Buttons
JDM Black Shifter Trim and Radio Bezel
JDM Knee Pads
2017+ One Piece Dash Bezel
Tomei Duracon Shift Knob
Old 11-10-2020, 09:58 AM   #77
Joveen
Joveen's Avatar
Drives: Bone stock
Wow!!! Dang son. Did you buy the 3" option?
Old 11-10-2020, 11:24 AM   #78
DarkPira7e
DarkPira7e's Avatar
I did! But my overpipe and frontpipe are still 2.5". Being EWG, I don't think the flow really be affected
The Following User Says Thank You to DarkPira7e For This Useful Post:
Joveen (11-10-2020)
Old 12-10-2020, 05:56 PM   #79
DarkPira7e
DarkPira7e's Avatar
Engine is here!! No plans to install yet, just getting all the pieces together
jflogerzi (12-27-2020), Joveen (12-10-2020)
Old 12-30-2020, 08:43 PM   #80
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
Did that motor come with the build clearances?
elitegunslinger is offline   Reply With Quote
Old 12-30-2020, 09:54 PM   #81
DarkPira7e
DarkPira7e's Avatar
I haven't opened the box. If it's something you need real bad I can open to see
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 12-30-2020, 11:21 PM   #82
elitegunslinger
Don't need it real bad, it can wait; just interested to see the stage differences if there are any in their clearances.
Pumped to see your build come together.
The Following User Says Thank You to elitegunslinger For This Useful Post:
DarkPira7e (12-31-2020)
Old 12-30-2020, 11:43 PM   #83
HaXx
Drives: jrsc_brz
My heavens, what have I been missing, ur building an iag block from the ground up? Wheres it being built??
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Old 12-31-2020, 12:41 AM   #84
DarkPira7e
DarkPira7e's Avatar
Hah no, IAG provided and assembled, I just gave them $, I am not an engine builder.
"Getting all the pieces" means for the build in general
HaXx (12-31-2020)
brz, frs, iag, jdl, turbo
Joel's BRZ - Low Budget Time Attack Build DIY Member's Car Journals 403 12-11-2023 06:59 PM
Cxracing turbo problem Kalebhall Forced Induction 10 11-16-2017 08:57 AM
Tony's Budget Turbo Build glorydays Member's Car Journals 22 01-26-2015 12:02 AM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 10:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 09:44 AM
