#43 | |
Hail Magnet
But its not named that in the manual. Toyota/Subaru does not intend for it to be used in that manner. Would I use it in an emergency if my brakes failed? Probably, but I also take good enough care of my car that I wouldn't let the brakes get to that point in the first place. I wouldn't expect it to perform as a method of stopping my car in an emergency either. And another side note, fun winter parking brake fact! |
| The Following User Says Thank You to HunterGreene For This Useful Post: | Tcoat (05-23-2018) |
#44 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
If you want to use the parking prawl in your automatic transmission vehicle to hold the car still, that's your prerogative, but that is IMPROPER OPERATION of the vehicle, regardless of how common it is to do. Using the parking prawl to keep the vehicle from rolling, especially on hills, puts stress on the prawl, and on the shift linkage, both of which can break as a result (think back to those times when you've had to tug really hard at the shift lever to come out of park on a steep hill because the prawl was loaded with the weight of the vehicle.) Your statement regarding a vehicle bumping you from behind is also false. A firmly set parking brake WILL help prevent damage to your transmission if your vehicle is hit while parked, because it will prevent the wheels from rotating too much. Otherwise, such an impact can potentially snap the parking prawl. Not only that, but IF the parking prawl is snapped by an impact, your vehicle could roll away. With the parking brake engaged, even if the impact is violent enough to snap the parking prawl, the vehicle won't roll afterward, which itself could prevent more damage to your vehicle, or other objects/people. It is simply wrong to not use it as a parking brake. That's what it is called, and that's what it is there for. End of rant.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#45 | |
Although I have used them as parking brakes hundreds of thousands of times I have indeed used it as an emergency brake no less than 3. As I said earlier the main use in modern cars is indeed as a parking brake. The use in older vehicles often was due to brake failure no matter how ell maintained your brakes were. Uses that I recall: Army Deuce and a Half truck. Plug came out of air brake accumulator. Fully loaded truck. Emergency! Hand brake worked and nobody died. 1964 Impala. Hit dog on highway. Dog rolled under car taking brake lines with him. Emergency! Hand brake worked and nobody except dog died. 58 Chev. Sudden and catastrophic failure of single master cylinder seal. Headed into intersect at high rate of speed. Emergency! Hand brake worked and nobody died. 91 Eagle Talon. Hit piece of tire on highway. Took out both front and back brake lines. Heavy traffic (which is why could not avoid said tire part). Emergency! Hand brake worked and nobody died. It is indeed intended to be used in that manner and hopefully it never will but if it does it will get the job done. Just don't pull the damn thing up into full lock!
| The Following User Says Thank You to Tcoat For This Useful Post: | HunterGreene (05-23-2018) |
#46 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
fun reading another over-analyzed ft86 thread
| The Following 3 Users Say Thank You to HKz For This Useful Post: |
#47 | |
Drives: toyota 86 2017
Canada has lower intensity of daylight due to latitude and having the DRL implemented as an mandatory requirement earlier than the U.S. was important. In reality, there has been research done that shows DRL doesn't have a big impact on accident prevention. |
#48 | |
How effective they are depends solely upon what study you want to side with.
#49 |
Drives: 2017 Halo 86
Happens to me too. Figured it was normal and no concern.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#50 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Holy semantics, Batman!
@bpennerz
#51 |
Hail Magnet
More like generational communication difficulties. (Its still a parking brake, and I use it as such). |
| The Following User Says Thank You to HunterGreene For This Useful Post: | SLVRSRFR (05-24-2018) |
#53 | ||||||||
A.K.A. Starlord
I enjoy a good debate, so I'll keep it going :P
![]() ![]() Quote:
As far as your examples, they are very specific, but I can give you plenty of others. What if you're in a parking lot, nose in to a spot, facing another vehicle. The vehicle in front of you pulled in after you, and is only 3 inches from your bumper (this is not an uncommon scenario.) Without the parking brake, it is likely that if someone else bumps your car while reversing out of their spot, it will easily roll at least those 3 inches, as the parking prawl method of parking leaves a LOT of slack in the drivetrain. With the parking brake immobilizing the rear wheels, you'll likely prevent having damage on both ends of your vehicle. Quote:
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Tcoat (05-24-2018) |
#54 |
Drives: 2017 series yellow BRZ
the ones that are on during the day are the day time running lights not the whole headlight. putting your car into park or pulling the e brake will not cut off the headlights off if they are on.
My BRZ Build Thread
http://www.ft86club.com/forums/showt...17#post3079417 |
#55 | |
What floors me is the total lack of understanding on how and why it should be used when parking or the simple FACT that it only turns off the DRLs and not all the lights. Even back in the early days when the headlights were the DRLs it would turn them off when parked and the actual headlights were not turned on.
| The Following User Says Thank You to Tcoat For This Useful Post: | HunterGreene (05-24-2018) |
#56 | |
Thanks. You saved me a bunch of writing.
| The Following User Says Thank You to Tcoat For This Useful Post: | Stang70Fastback (05-24-2018) |
| Help please. maybe battery bad but shuts off while driving | Nefarious | Issues | Warranty | Recalls / TSB | 13 | 03-20-2017 11:14 PM |
| Head Unit Randomly shuts off and restarts during drive | Natheria | Issues | Warranty | Recalls / TSB | 6 | 01-08-2015 10:29 AM |
| car beeping after engine shuts off | mystic | Southern California | 10 | 04-14-2014 06:47 PM |
| Nürburgring shuts down.. | Hanakuso | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 04-10-2013 03:17 PM |
