Old 05-18-2018, 10:18 AM   #1
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Heard a crunch in the rear
Put spacers on a few weeks ago to get rid of the awful stock "sunken in" appearance. Took a sharp turn at only 15 mph this morning on the way to work and heard a loud metal clunk in the rear over my loud music. Turned hard again to recreate it and heard it again. Got out to inspect and one of the rear wheels has the suspension sitting 1/2" lower than the other side. I'm hoping that I'm just parked on uneven pavement?
I was going to be doing my brakes tonight anyways at my buddy's house, so what should I be looking for? I'll check the torque of the spacer lugs, could this be making the noise? Are there any weak points of the rear suspension I should be aware of?
Thanks!
majixmatrix is offline   Reply With Quote
Old 05-18-2018, 10:55 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If one side is sitting lower, that sounds like a spring lost it's place on the perch. Very unlikely, but just verify it sits nicely on the perch. Other candidates may be binding swaybar bushings, a loose strut top hat (very unlikely as well).
I'd give the suspension some tugging all over and see that everything looks normal. Likely has nothing to do with your spacers unless they're coming loose, but you can check that they're snug easily enough. Let us know what you find!
broken, clunk, spacers, suspension
Crunch noise? winsometang Issues | Warranty | Recalls / TSB 9 12-02-2014 02:38 PM
Transmission Crunch when Flooring Throttle kdbar Issues | Warranty | Recalls / TSB 21 08-24-2014 02:00 AM
High RPM 3rd to 4th Shift Crunch calmtigers Issues | Warranty | Recalls / TSB 1 08-01-2014 08:08 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
Second Gear Crunch? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 18 09-27-2012 03:52 PM
