#43 |
Drives: 2015 Firestorm FRS
My front has -0.4 camber
-2.2 rear. Trd lowering springs Do i need camber bolts and lca? |
#44 |
Drives: 2014 GT86
If you are happy with how your car handles with this alignment, why would you need it.
If you want to change it, you need adjustability. Camberbolts & lca is most common way to get it. Your own choice/preference, what you want. |
#45 |
Drives: '23 BRZ
LCA's are overprescribed. You don't need them, -2.2° is totally streetable, particularly if you run zero or near-zero toe and rotate tires. IMO -0.4° camber up front is still woefully low, you might get camber bolts to bump that up to -1° (and you'd want a lot more than that for track/autox) but not necessary.
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | GoZ21 (05-22-2018), strat61caster (05-22-2018) |
#46 |
Drives: 2013 FR-S Asphalt
Yes - What ZDan said. I'd get the SPC camber bolts for the front and aim for -1.5* and keep the rears as is.
2013 FR-S Asphalt Grey
HKS Hipermax IV GT Sparco Assetto Gara MGC 17x7.5 Invidia N1 exhaust |
#47 | |
Drives: FR-S Whiteout
I have the bolts adjusted to max positive on driver side and max negative on passenger side to even out the camber. In terms of total negative camber gained (left + right side), its none. not much adjustment in them.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | GoZ21 (05-22-2018) |
#48 | |
Yes. I dont do track or autox. Only for daily.
I just want like the factory set up. For equal threading of tires. So -2.2 at rear is set. Then -1.5 in front using camber bolts. Btw Trd lowering spring Stock struts 17x9+38 w 245/40/17 is my setup Quote:
#49 |
Drives: FRS
After reading this review, I am going to buy Godspeed coilover. How it is?
#50 |
Drives: 2017 toyota 86
Tein Flex A seems to be the only coilover worth getting for under 1k. Other wise just get RCE yellow or TRD lowering springs will be as good or better performance/ride quality as any other coilover under 1k.
#51 | |
Drives: '20 Hakone 86
Save your money. Be patient. Buy something that’s actually worth buying. The KWs are probably the only ones on that link that I’d spend my own money on.
| The Following 2 Users Say Thank You to TylerLieberman For This Useful Post: | DarkPira7e (07-19-2020), Tokay444 (07-20-2020) |
#52 |
Drives: '23 BRZ
Bilstein B6/B8 with springs (RCE yellows or tarmac, Swift sport or Spec R) is a great option IMO. I'm really impressed with the Bilsteins/Spec R setup I just put on my car a few months back.
#53 | |
TRACKBREAD
How is the high speed damping on the B6/RCE yellow combo? I’m trying to find a more comfortable damper setup than the PP Sachs. |
#54 | |
Drives: '23 BRZ
![]() Also theres more low-speed damping so better compatibility with the stiffer lowering springs like RCE Tarmac and Swift Spec R |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | Racecomp Engineering (07-19-2020), Yoshoobaroo (07-19-2020) |
#55 | |
TRACKBREAD
Excellent to hear! Looks like B6s are in my future. |
#56 | |
I got KW/GReddy. I feel like for the money, they’re hard to beat, along with the RCE SS1, CSG FLAs, and ST XTAs.
| Tags |
| coilovers |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 01:09 PM |
| FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns | b2autodesigns | Brakes, Suspension, Chassis | 177 | 02-09-2015 12:34 PM |
| WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers | ProjectBrz | Brakes, Suspension, Chassis | 1 | 04-15-2014 01:21 AM |
| * BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * | Speed Element | Brakes, Suspension, Chassis | 21 | 03-03-2014 09:56 PM |
| FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers | ill roller | Brakes, Suspension, Chassis | 5 | 12-14-2013 04:02 PM |
