Old 05-16-2018, 04:24 PM   #1
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Jacking rails for a Twin?
Coming from the Mustang world, jacking rails are a very common addition to the unibodies of those cars, usually in conjunction with subframe connectors. Having had my BRZ up on jackstands frequently since getting it, I noticed that the metal at the jacking points of the body is folding over just a little bit. For a car that sees floor jacks as often as these do, I would think it makes sense. Is there any reason not to? It sure would be nice to stick a jack under the frame below the door and jack the side up front and rear without hurting anything. I would think any good race shop would be able to make something very simple and stitch weld the whole thing in less than an hour. Or even better, come up with a bolt on solution...
So my question is, have any of you added, or seen added, jacking rails to a Twin?
(The pics are of Steeda rails for a Mustang and a Focus ST, in case you are unfamiliar)
bmxr is offline   Reply With Quote
The Following User Says Thank You to bmxr For This Useful Post:
Tristor (05-16-2018)
Old 05-16-2018, 04:33 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
That's an interesting idea. I also wanted to avoid bending my pinch welds. I just got ESCO jack stands. Seemed like the simplest solution. They have a huge, flat rubber pad that is big enough that they don't damage the pinch welds at all.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-16-2018, 04:37 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Huh, never heard of these but is a cool idea. Idk where we would be able to connect them without drilling through the frame, which might be worse?
Old 05-16-2018, 04:51 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I put a length of 2x4 between the jack and the bottom of the rail before jacking. Wood deforms before bending steel rail.
krayzie (05-30-2018)
Old 05-16-2018, 04:59 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Just use the proper tools and you will be fine. No need to add anything like a Ford.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
86kahl (05-19-2018), BirdTRD (05-16-2018), extrashaky (05-16-2018), Mr.ac (05-17-2018)
Old 05-16-2018, 05:06 PM   #6
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Great question, I'd love to have some jacking rails added on the sides. My jack-stands have a cup that works well with our pinch welds, but I would like to be able to use something like a quickjack very easily and specific jacking rails would make that easier.
Tristor is offline   Reply With Quote
Old 05-16-2018, 05:36 PM   #7
DrButtDrugs
yerp
Drives: 2015 WRX
My pinch welds are bent.
DrButtDrugs is offline   Reply With Quote
Old 05-16-2018, 06:02 PM   #8
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I use these:
This thread is pretty helpful too:
https://www.ft86club.com/forums/showthread.php?t=10111
I don't jack my car up from the sides though, only the front or rear.
Jacking the car up from the side should really only be done in emergency situations like a flat tire or such.
The twins (and most cars) are really only designed to be lifted from the front or rear..
Lifting from the side can cause damage to your pinch welds, and will twist and tweak the chassis.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
why? (05-18-2018)
Old 05-16-2018, 06:17 PM   #9
daskaman
Drives: Burz
Just cut a groove in a hockey puck
daskaman is offline   Reply With Quote
The Following User Says Thank You to daskaman For This Useful Post:
Gunman (05-16-2018)
Old 05-16-2018, 06:18 PM   #10
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by JeremyR View Post
I use these:
Do you have a link for those stands?
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
JeremyR (05-16-2018)
Old 05-16-2018, 06:45 PM   #11
JeremyR
JeremyR's Avatar
yup!
Jackstand
Jackpad
They are pretty reasonably priced, but shipping is a killer.. :/
I just tell myself its a small price to pay to keep my pinch welds in good shape
Yoshoobaroo (05-16-2018)
Old 05-16-2018, 06:55 PM   #12
Yoshoobaroo
TRACKBREAD
yup!
Jackstand
Jackpad
Thanks!
Hmmm. Did you have to make a new account for Amazon Japan ?
Edit: turns out yes, Amazon US accounts cannot login to Amazon Japan.
Old 05-16-2018, 07:46 PM   #13
JeremyR
JeremyR's Avatar
Yeah I had to make a new one too. Seems kind of silly. You'd think one amazon account would work for everything :/
Old 05-17-2018, 02:36 PM   #14
bmxr
bmxr's Avatar
There's always one...
I could jack my Mustangs up from the side jacking points without ever causing any damage to the pinch welds, so Ford is a step ahead of Subaru there. The jacking rails are so you can lift both tires from the side instead of just one at a time, and so the exact spot matters less if you happen to be on a track and doing this quickly and frequently..
The twins (and most cars) are really only designed to be lifted from the front or rear...
According to Subaru, the car is designed to be jacked from the jacking points, which include the four specific spots on the pinch welds. Subaru didn't do a very good job of reinforcing those areas though.
Lifting your car from the side will definitely not "tweak the chassis". Where did you get that from? It can damage the pinch welds, though, hence the jacking rails, hockey pucks, 2x4s, etc.
Nevertheless, I have been jacking the car up only from the front and rear, also per the manual, but it's the jackstands that are causing damage to the pinch welds. I don't know about you, but I'm not getting under the car without jackstands, so the front/rear jacking does not solve the problem.
I use one of those plastic pucks things with a groove in it, or a piece of wood, when I jack from the sides but I usually jack front or rear and place jackstands on the sides. Hockey pucks and 2x4's do not work with jackstands.
norcalpb (05-17-2018)
Jacking up car from tie dow hooks edigeek Scion FR-S / Toyota 86 GT86 General Forum 3 09-20-2016 01:01 AM
Jacking points? bleox Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 02-19-2016 01:03 AM
Jacking points Qwimby2 BRZ First-Gen (2012+) — General Topics 4 12-08-2015 09:48 PM
Jacking a lowered BRZ/FRS? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-19-2013 02:04 AM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
