#29 |
Drives: Q5 + BRZ + M796
I have the OLM ones.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Busybee (08-26-2019) |
#30 |
I installed the OLM DRLs. Oddly enough, the length of the harness between the two lights is so short that there is no way to snake the wire through the body to tuck it nicely. It is so taught that it hangs between the two harnesses like a hammock. I decided to lengthen the harness by two feet, so I cut, soldered, heat shrink'ed and covered up the wires.
I already had the DD Always-On harness, so I tapped into that for the two wires (black and white), but someone could do the same for the stock DRL harness to get their ground and power for the new bulbs. The setup appears to work perfectly, except neither the boomerangs, nor the DRLs, dim when my headlights come on like they use to do, so maybe that is an issue; I don't want to be too bring at night.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Busybee (09-08-2019) |
#31 |
Drives: BRZ limited
Great! Any pictures for the OLMs turned on and off?
Meanwhile, what’s the always on module and is that for all versions including 2017+? Thanks Sent from my iPhone using Tapatalk |
#32 | |
I just assembled my stuff and have yet to verify in every mode that I’m getting the same operation like I had prior to the install, but it seems to be good.
#33 |
Drives: BRZ limited
Since I am not an expert, does anyone have a write-up or pictures for the wiring? I really want these JDM ones but do not want to have someone install (cutting wires etc) it which might cause issues later. I would like to follow up on an installation from someone who successfully installed it.
Thanks |
#34 |
Drives: BRZ limited
Got the JDM DRL and any installation guide or video will be appreciated.
![]() Sent from my iPhone using Tapatalk |
| FS: 2017 86 Bumper Socal | Akuma-ZN6 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 03-16-2018 01:40 PM |
| 2017 front bumper | Jmk91 | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 12-13-2016 02:15 PM |
| WTB BRZ front end (bumper-whiteout, headlights, DRLs, and fog light) | jupillam | Exterior Parts (Aero, Lighting, Etc.) | 0 | 06-12-2013 07:15 PM |
| Difference Between $3 DRLS and $40 DRLS? | FR-S Matt | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-31-2012 06:05 AM |
