#57 | |
#58 | |
Only users lose drugs.
Drives: All the time
EDIT: Nevermind...I looked up Lucas Synthetic SAE 75W-90 Gear Oil, and it's rated as GL5. No bueno.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | gravitylover (01-28-2020), Spuds (01-28-2020) |
#59 |
Drives: 2013 Firestorm Red FRS
Have you ever run Motul fluid in the trans? I'm about to switch to that since this Redline 75W-90 isn't much better than stock, especially in the cold. Wondering if I should try Amsoil next year after Motul.
Also have the Perrin shifter bushing, along with the Whiteline trans mount insert and MTEC shifter springs. |
#60 | |
The Dictater
Drives: '13 Red Scion FRS
#61 |
Just the first 2 miles back on the stock rear diff fluid was MUCH better.
#62 | |
Stock, Motul, Redline in the diff all feels the same to me, the gears do all the work and the oil just keeps stuff lubed. Last edited by strat61caster; 01-28-2020 at 06:19 PM. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Spuds (01-28-2020) |
#63 |
Drives: 2017 Subaru BRZ Limited
I love AMSOil and it's all I run for engine oil. But after significant testing, I can say that I've had better results with Motul in the diff and Redline in the trans (ATF) for predominantly track usage in Texas (where higher temperatures occur and I don't deal with low-temp conditions). YMMV, but just wanted to throw that into the thread. I have switched away from AMSOil except for my engine oil.
| The Following User Says Thank You to Tristor For This Useful Post: | COBlue (02-18-2020) |
#64 |
Drives: Toyota GT86
I just ordered amsoil for my transmission to replace motul gear 300 after reading it might cause damage to the brass synchros. I am still using gear 300LS in the diff though but might swap it out for amosil severe gear
2014 GT86 Orange 6 Speed https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#65 | |
Purchased 6/22/12
Synchros still seem to behave the same as day one. Not sure where u read gear 300 is hard on brass. https://azupim01.motul.com/media/mot...0_20221014.pdf Suitable for any type of seal and yellow material used in gearboxes design. Anti-corrosion, Anti-foam, Anti-emulsion.
#66 | |
Drives: Toyota GT86
#67 |
Drives: 2018 Subaru BRZ
Update: While replacing my TOB, I replaced all fluids to AMSOIL (Coming from MOTUL) and boy does the car feel so much, so much better. No more notchy gears. Smooth shifting all the way through. The car feels more engaging in every possible way.
I highly recommend to use the EZ-Packs. I couldn't find it for the Differential oil, but for the transmission it was super helpful.
#68 | |
Drives: 2018 BRZ
Thanks for the recommendation on the Amsoil fluids, though. I used Redline and wasn't impressed with the shifting quality (overall I preferred the OEM fill). |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | spcmafia (05-02-2023) |
#69 | |
I got a Penzoil transfer pump that I got from Amazon and it worked wonderfully for the differential. With the transmission, I inserted the EZ Pack tip and then held it with one hand while I rotated the bottom bag up towards the engine bay, there was plenty of room since as it empties it becomes easier to maneuver. Though the pump is handy, it can become a little messy with residual oil left on the hoses or inside the pump.
| The Following User Says Thank You to spcmafia For This Useful Post: | Ohio Enthusiast (05-02-2023) |
#70 | |
Drives: 2018 BRZ
I got the same one
![]() Quote:
Agreed. I tried to be careful and drain the excess fluid in the pump and hoses back to the bottle and any minor leftovers into the drain pan, but still made a bit of a mess. |
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 02:20 PM |
| Transmission oil change 2nd time - previously amsoil | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-08-2017 12:47 AM |
| Amsoil Oils Complete Change | BC-Boy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 04-25-2014 02:04 PM |
| Was doing the transmission and diff oils today, when... what is this thing? | Entroper | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 03-12-2013 12:40 AM |
