Old 05-13-2018, 03:39 PM   #15
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by Jaden View Post
It cost me $150 to go flex fuel and it's definitely worth it to not have to worry about flashing back and forth...
Jaden
p.s. There is no reason to spend $2000 on a flex fuel kit and tune. Especially if you already have an OFT. If you need help, let me know. I can get you a fuel analyzer and tell you everything you need for the most bang for your buck.
Where's this $150 flexfuel kit?
Old 05-13-2018, 04:00 PM   #16
coxxoc
Why couldn't you just make a summer tune for better than e60? Also, it has been explained that there REALLY isn't any real gains to be had over e60.
The amount of additional timing you can run is negligible.
Jaden
I could. If the user is fine with flashing the ECU every time they change fuel types that is fine. I didn't carry around an ethanol tester, however. Once I spent the money on the flex fuel kit/ethanol content analyzer going the rest of the way to a flex fuel tune wasn't that much.
What do you know, it is May when we should have class 1 E85 in AR. Its still class 3 here. 66% ethanol (as measured by the ECA) instead of the 80%+ it should be. Its a safer decision to let the map adjust based on ethanol content rather than switch maps due to time of year and hope for the best. Hopefully this clears up why I never advanced timing for more than E60 before.
Regarding timing advance. I'll be adding a turbo in the next 12 months. E60 vs E85 timing matters with boost.
coxxoc is offline   Reply With Quote
Old 05-15-2018, 04:07 AM   #17
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Originally Posted by Bkdshadow View Post
I’m pretty sure @Xxyion had an OFT OTS E85 tune originally, but then switched to the Delicious E85 flex fuel tune. Maybe he can chime in on this.
I had the OFT but never ran E85 as at the time I had no access to it. @MYKey and @mrpikachufrs both use the OFT with the E85 tune. I’ve driven one before and personally I found the custom flexfuel tune to be significantly superior both in throttle response and power delivery.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
Bkdshadow (05-15-2018), paintdude258 (05-24-2018)
Old 05-15-2018, 11:51 AM   #18
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
There isn't one...
It's called ability and ingenuity....
I bought a flex sensor and fuel lines on ebay for $89...
Then I bought an arduino nano and display for $12, and $6 respectively. Then I coded said arduino to convert the frequency output of the flex sensor to voltage output and ethanol content percentage display, I got a visconti pnp harness for $45 also on ebay and I got the flex tune from Shiv.
I offered to give anyone who wanted my fuel content code. I am also willing to send programmed and soldered/shrink wrapped(requires a couple of resistors) and boxed arduinos with instruction on how to wire them up to the car for $90 bucks...
Jaden
p.s. even if you were to buy everything brand new, it shouldn't cost much over $200... and you could do it for as little as a hundred with the right deals and going directly into your own harness...
Jaden is offline   Reply With Quote
The Following 3 Users Say Thank You to Jaden For This Useful Post:
paintdude258 (05-24-2018), slacker221 (05-25-2018), Yoshoobaroo (05-15-2018)
Old 05-24-2018, 11:07 PM   #19
paintdude258
paintdude258's Avatar
Definitely some ingenuity there, mad props my friend!
Although enticing, I will spend the money for peace of mind rather than saving the money! Thank you for the write up, a great find for the DIY’r!
I offered to give anyone who wanted my fuel content code. I am also willing to send programmed and soldered/shrink wrapped(requires a couple of resistors) and boxed arduinos with instruction on how to wire them up for $90 bucks...
Jaden
paintdude258 is offline   Reply With Quote
The Following User Says Thank You to paintdude258 For This Useful Post:
Jaden (05-25-2018)
Old 05-24-2018, 11:08 PM   #20
paintdude258
YOU ARE THE MAN! This was exactly the answer I was looking for! I have run Shiv’a custom 93 tune and his OTS tune.... the custom tune is night and day better!
Custom FP/OP willharp360 Engine, Exhaust, Bolt-Ons 14 02-26-2016 06:27 PM
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 11:35 AM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 03:01 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 12:42 PM
Custom Intake? wootwoot Engine, Exhaust, Transmission 3 04-29-2014 12:42 PM
