Old 05-07-2018, 05:24 AM   #1
khcho19
Drives: ford focust ST
Does BRZ tS have different suspension from standard model?
As you know, BRZ tS has bigger 18x7.5 wheels while BRZ premium or Limited model has 17x7.5 wheels.
So i guess tS model has different suspension (and lower the car) from the standard models.
Does anyone have information about this?
khcho19 is offline   Reply With Quote
Old 05-07-2018, 05:58 AM   #2
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I heard the wheels are black.
krayzie is offline   Reply With Quote
Old 05-07-2018, 08:56 AM   #3
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
http://lmgtfy.com/?iie=1&q=2018+brz+ts+suspension+specs
Slammillionaire is offline   Reply With Quote
The Following 2 Users Say Thank You to Slammillionaire For This Useful Post:
bkharmony (05-07-2018), NCtoBRZ (05-07-2018)
Old 05-07-2018, 09:25 AM   #4
Rai-zero
Drives: Legacy
The tS wheels are larger but the tire circumference/height are the same. This is because the tire is lower profile. So the net effect is the same ride height.
Rai-zero is offline   Reply With Quote
Old 05-07-2018, 01:29 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I mean this in a friendly way but, do you know how to use the internet? I mean you are on a forum asking questions that you can easily search yourself.
https://www.subaru.com/2018-brz-ts
Click "Features and Gallery" and read text at bottom while you scroll through the pretty pictures.
No one is bothered by someone asking questions but when you ask questions that are easy to find out on your own it makes people Please don't make 4 threads about this too.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bkharmony (05-07-2018), why? (05-07-2018)
Old 05-07-2018, 02:10 PM   #6
bentleyboii
bentleyboii's Avatar
Drives: 2022 GR86
Info From Press Release Etc
"The tS employs German Sachs dampers that are tuned differently than those on the standard BRZ. They are 15 perfect stiffer in the front of the car and 3 percent stiff in the rear. The suspension setup as a whole has been retuned, resulting in 10 percent less roll reduction and 15 percent less pitching. Brembo handles braking duties. The wheels are now 18-inches shod in sticky, grippy Michelin PS4 215/40R18 tires. Do all of the tweaks add up to STI’s goal of pure handling delight?"
"Next, STI added flexible V-bars to the engine bay. The V-bars look like a typical V-brace, but halfway down the length you see that each bar is actually two bars connected by pillow ball joints, the idea being that allowing a little movement on each bar will reduce harsh impacts and result in better suspension behavior. There are also two flexible draw stiffeners connecting the front subframe to the body. The idea here is to reduce yaw time and improve steering accuracy. Still with me?"
From http://www.motortrend.com/cars/subar...-drive-review/
bentleyboii is offline   Reply With Quote
Old 05-07-2018, 09:40 PM   #7
Rai-zero
Drives: Legacy
Loving my tS
Old 05-07-2018, 10:11 PM   #8
krayzie
Drive From Home
krayzie's Avatar
STI springs are supposedly 15mm lower than the standard car.
Standard Suspension Bump Travel 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 87 07-26-2017 11:33 AM
Stock 10-series HID w/ DLR install on standard model FR-S Feathergun Cosmetic Modification (Interior/Exterior/Lighting) 1 01-29-2017 05:54 PM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 12:49 PM
Breaking: standard Scion FR-S / Toyota FT-86 model and aero kits revealed Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 234 08-19-2012 08:33 PM
