#57 | |
When trying to locate the TireRack test you were referring to I came up with this video: [ame="https://www.youtube.com/watch?v=73Wa-uW2-dI"]Toyota 86 - Stock vs Track (Yokohama AD08R) Tire Comparison - YouTube[/ame] 215 OEM vs 225 AD08R. |
#58 |
I didn't read the whole thread but rotational mass doesn't equal static weigh. 12lbs in the wheels has more negative impact than having 12lbs in your passenger seat.
#59 | |
Drives: 2017 BRZ WR Blue
Sounds like a solution to me
#60 |
$5448
| The Following User Says Thank You to Tcoat For This Useful Post: | JohnJuan (05-10-2018) |
#61 |
Those lighter wheels are going to raise the center of gravity and ruin the handling according to some.
Drive upgrades. Don't buy them.
#63 |
Drives: 2018 BRZ Limited, 2017 Sportage
Are you kidding me? The COG, according to what I've read, is about 18" high. The mass of the car is about 2800 lbs. The mass of the wheels is about 180 lbs total. The COG of the wheels is about 12.5". For arguments sake, let's say extra light racing wheels with tires would weigh about 150 lbs. Extra wide/heavy racing wheels would weigh about 250 lbs, max. So you have an increase of about 100 lbs. divided by 2800 lbs., so your COG would rise by about 0.2 inches. And that's going to "ruin" the handling? Are you kidding me? Then you have to consider that carrying an extra 100 pounds will slow down the car and wide wheels on the front will reduce handling. So adding weight is good for performance. You got me on that one. We'd better tell all of those racing teams out there of this new paradigm.
| The Following User Says Thank You to rvoll For This Useful Post: | JohnJuan (05-10-2018) |
#64 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I don't think the stock wheel/tire selection used is optimal though it works well enough. My preferred optimal setup is slightly wider and noticeably lighter 17x7.5 wheels with a slightly smaller diameter and not too much narrower 205/45-17 MAX performance tires. That combo drops over 4lbs a corner on inexpensive 17lb Enkei wheels and 19lb Continental tires, lowers the car CG ~.2", and provides better throttle responsiveness, all while greatly increasing grip and really quickening chassis responsiveness (because the 205 Continentals are more optimally matched for a 7.5" width wheel than the stock 215 tires on 7" width wheel).
The wheel and tire change is small, but the felt difference isn't. Toyota/Subaru should have gone with 17x7.5 wheels and 205/45-17 tires as the stock setup, but probably the slightly reduced load capacity and reduced ground clearance or theoretically worse fuel mileage were the reasons they didn't. For daily driving a lightweight 17x7.5 wheel with 205/45-17 Max Performance tire will make the stock setup feel incompetent - much more planted to the pavement yet also quicker to react and more precise in its reaction. That's my two cents...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
| The Following User Says Thank You to Vracer111 For This Useful Post: | SuperTom (01-20-2019) |
#65 | |
[ame]https://www.youtube.com/watch?v=FSqWD5BSeoY[/ame] |
#66 | |
#67 | |
I think he was kidding. |
#68 |
Drives: 2014 GT86
It's not just the center of gravity, that will be ruined! Lighter wheels also don't have enough gyroscopic effect, so car will become very unstable and uncontrollable!
#69 |
Is 12lb total difference in weight going to affect a lot?
#70 | |
Drives: '14 Monogram, '95 Miata, '90 300ZX
That's the whole better feeling vs. physically optimized concept again. Also maybe a bit because this vehicle was designed to have a certain track width and most wider aftermarket wheels that people put on them will change this slightly. I'm not trying to say turn it into a steam roller. Eventually you will hit marginal returns and yes, you will lose out on acceleration and braking capability a lot if you stay at stock power levels. However, look no further than the BRZ race cars if you think anything even close to a stock width tire is optimized for handling. |
| How much does wheel weight affect performance? | Slammillionaire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 89 | 07-05-2019 03:20 PM |
| 3 pound weight difference? | UtahSleeper | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 07-05-2017 01:21 AM |
| FR-Sandwhich: Total or not total? | Joshwahhhs | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 10-03-2015 09:11 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 12:38 PM |
| weight difference between auto and manual??? | sofrsnsokleen | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-23-2012 12:40 AM |
