86WORX
Old 04-13-2018, 04:33 PM   #15
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by NordicGT86 View Post
The warranty is 100,000 km (62,500 miles) or 3 years.
Yes, it is same in Germany. What oil grade are you using? 0w20 or 5w30?
Old 04-13-2018, 04:48 PM   #16
NordicGT86
Drives: GT86
I am using 5W-30. I my opinion the engine works with high oil temperature without oil cooler.
NordicGT86 is offline   Reply With Quote
The Following User Says Thank You to NordicGT86 For This Useful Post:
nikitopo (04-13-2018)
Old 04-13-2018, 04:55 PM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes and no. The oil temperature sensor is not located in the oil pan, but after passing the engine. So it is gives the highest possible temperature. Other manufacturers are placing it in the oil pan and it reads 10-12 C lower. Of course, it doesn't hurt to use a 5w30 oil. I use the same grade. It is better if you run the car harder.
Old 04-13-2018, 05:03 PM   #18
reeves
And it can't possibly be because they figured out how to make them more efficiently, hell no.
Well that's true, they could've made them more efficiently.
Cool your tail pipes though.. didn't you see my smiley face, I was just being sarcastic. I'm sure that kid in their sweatshop agrees with me too
But America's oil is still "cheaper" quality than the European oil, synthetic or not.
That's the main reason for the discrepancy between the different oil change intervals by the manufacturer... for the same car.
reeves is offline   Reply With Quote
The Following User Says Thank You to reeves For This Useful Post:
strat61caster (04-13-2018)
Old 04-13-2018, 05:26 PM   #19
NordicGT86
Drives: GT86
That's true. I had not thought in your point. But, you are absolutely right. You read the manual, all Toyota Cars have thé same oil. 0W-20 the universal solution, from Aygo to GT86, hybrid or gasoline. All of them have the same oil and service program. Doesn't have to much sense. My feeling is you don't drive an Aygo in the same manner that GT86. Maybe just for fuel economy they can use the same oil.
Is 0W20 the adequate viscosity for driving hard a GT86?
Old 04-13-2018, 05:27 PM   #20
reeves
5W-30 could mean something totally different in Europe, since they tend to focus on lower viscosity in general. It'd be interesting to compare the 5W-30 oil specs over there to something similar over here.
There's just different standards and goals that Europe & America are trying to achieve.
Here's one article explaining the differences between the oils:
https://www.autoserviceworld.com/car...european-oils/
I'm sure there's other articles on the subject, but that gives you a good idea on why Europe can & does specify longer oil change intervals.
Old 04-13-2018, 05:51 PM   #21
strat61caster
strat61caster's Avatar
tfw manufacturers make oil that meets ILSAC, API & ACEA
tfw viscosity is tested via standard SAE procedure around the world
5W-30 absolutely means the same in the US as it does in Japan or Germany
ineedyourdiddly
reeves (04-13-2018)
Old 04-13-2018, 06:20 PM   #22
reeves
By "could mean something totally different" I meant "could be something drastically better". European oil often times go above & beyond the 'minimum' requirements of car makers (and US standards for that matter). They have different additives in their oil to achieve different goals with the cars there.
Could be something, or could be nothing... I think it's something. They've got different standards from the U.S., and that's reflected in car makers' oil change specifications.
Old 04-13-2018, 06:28 PM   #23
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
I too, wonder about this
86kahl is offline   Reply With Quote
Old 04-13-2018, 06:41 PM   #24
reeves
For 75K miles, it has so far for me!
But when you think about it, I don't doubt that the 0W-20 specification is heavily influenced by the complicated (and stupid) mathematical formula of the CAFE regulations requiring car manufacturers to raise the fuel economy of ALL their cars (on average) to 34 mpg.
I know I didn't explain it well, but it's boring.. and like most things in this country (including motor oil 'standards') there's plenty of politics behind it. You can read more about it here: https://en.wikipedia.org/wiki/Corpor...e_fuel_economy
Since Europe doesn't have to deal with the CAFE regulations, and since they have different oil qualities as well, the 5W-30 oil suites them just fine... even in the freezing weather of Sweden, right OP?
Old 04-13-2018, 08:14 PM   #25
JIM THEO
Drives: BRZ 2018
Isn't the viscosity itself that describes a good oil for our engines and so far there aren't big differences in European and USA engine oils and additive packages on them, there are remarkable American oil companies for heavy use say Redline, as European say Motul Fuchs Elf and so on.
Viscosity index, Total base number (longevity/service intervals) and more importantly HTHS (stability on continuous high temp) is what we should search on a good oil no matter if it is 0/20 (ILSAC/fuel economy reasons only) 5/30 (only Mobil1 AFAIK is ILSAC) or higher viscosity!
For heavy street use or track driving an HTHS index less than 3,5 may be detrimental for the engine if we haven't an oil cooler which leads us to an oil of 5W30 and higher viscosity, only repeated UOAs may tell the truth about the oil we use, oil service intervals and driving habits.
Otherwise we should choose a very good >=5W30 oil as the factory oil sensor is in the correct place on the engine block and reads real oil temps not lower than those the oil achieves as other manufacturers do.
So IMHO the answer is NO, 0W20 isn't adequate for heavy street use even in cold climates!
JIM THEO is offline   Reply With Quote
Old 04-14-2018, 03:18 AM   #26
NordicGT86
Drives: GT86
[/IMG]
The issue with the ACEA classification is that there are a lot of categories. Then, when you go to the oil shop you will find just from one brand and one line product several versions ACEA A1/B1, A3/B3, A3/B4, ACEA A5/B5, C1, C2, C2, C3, C4, C5.
At least in European Toyota cars donīt says a single word about ACEA. The manual only refer to the API classification (API SN).
In the picture that you uploaded it is A1/B1, but you have several options. Please give a look just for Castrol Edge
What is the more adequate for your application? (Eco drive/spirit drive/heavy track sessions)
The owner manuals donīt talk about that.
https://msdspds.castrol.com/msdspds/...edmb=No&cols=0
Old 04-14-2018, 07:18 AM   #27
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
The engine is a glorified economy car engine. For normal driving it will work great. The more you beat on the car and drive it like an actual sports car, the more you want better high temp protection, ie an oil cooler, thicker oil, and changing the oil more frequently.
Old 04-14-2018, 12:11 PM   #28
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's 5 years in Belgium , same kilometers though.
Toyota EU headquarters is located in Belgium, that's why we get 2 more years.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Oil Change Intervals (Winter Storage Advice) Mr.Impreza Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 10-21-2016 05:09 AM
What's a reasonable starting point for fluid change intervals? hpde_addict Tracking / Autocross / HPDE / Drifting 14 09-16-2016 08:42 PM
What are the oil change intervals listed for 2015 cars? pantdino Issues | Warranty | Recalls / TSB 8 09-06-2015 02:36 PM
Oil change intervals? nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-10-2014 05:06 PM
