Old 04-10-2018, 09:13 PM   #1
Dillydallen
Dillydallen's Avatar
Drives: AimGain FR-S
JDL Turbo Manifold, 3" Downpipe & Wastegate Dump - CERAMIC COATED
Selling the hot parts off my JDL Turbo Kit because I switched to a different setup from JDL. This setup is made to work with a V-Band turbo, in my case I was running a Garrett GT with a Tial housing. This setup has 2 minor dents on the downpipe which are pictured. There are no defects, fitment issues, or anything wrong with these pieces at all. All of the parts are thermal coated bronze.
This setup is around $2,000 from JDL when including the thermal coating, which truly helps, a lot. JDL is local to me, & these pieces are top notch quality. Like I said, only reason for sale is me switching up my setup & was easier for all new hot parts to be made for me by JDL, so I replaced the entire setup.
I want $900, can ship anywhere in the US upon arrangement. These are off the vehicle, boxed up & ready to go.
Only trades would be -
Aftermarket Clutch
Overpipe & or FrontPipe
3" Catback Exhaust
Big Brake Kit (front)
Thanks for looking. Contact me here directly, I get notifications.
Dillydallen is offline
Old 04-12-2018, 02:17 AM   #2
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Are youconsidering 04-07 sti brembos?
BRZ RN is offline
Old 04-12-2018, 10:04 AM   #3
Dillydallen
Hello, interesting to me. Can you PM me the details of the swap & more details of what you have? I have not looked into the STI brake swap & want to stay with something bolt on, opposed to a setup where you need multiple brackets, re-drilled rotors etc. Just not sure how the STI setup works so if you could PM me details, I would appreciate it!
Thanks!
Old 04-12-2018, 11:37 AM   #4
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Thanks!
i Just saw the V band connection, unfortunately my turbo doesnt have V band connection. the STI swap is from 04-07, it uses a bigger rotor and caliper, usually there were arguments against using it due to more front bias and how it is front mounted at the front and rear mounted from 04-07 sti. but some people did it and were using it. look it up on google "brembo sti brz" usually these are colored orange.
BRZ RN is offline
Old 04-12-2018, 12:18 PM   #5
Dillydallen
Ah, thanks for the clarification. If you ended up wanting to work something out, let me know. Easiest way to make this setup work is purchase the Tial housing for your turbo & everything bolts up.
Old 04-18-2018, 10:42 PM   #6
Dillydallen
SOLD
FA20 Club 4-1 Header / Turbo manifold Ceramic Coated Dallen Engine, Exhaust, Bolt-Ons 6 06-30-2022 03:03 PM
FS - JDL UEL Turbo Manifold DP & Dump JDLAutoDesign Engine, Exhaust, Bolt-Ons 23 03-10-2016 07:25 PM
Jdl ceramic coated downpipe. never mounted Shit Luck Engine, Exhaust, Bolt-Ons 5 04-13-2015 12:04 PM
TGS| AVO Stage 1 Turbo Kit w/ FMIC (Ceramic Coated) For Subaru BRZ / Scion FR-S TopGearSolutions Forced Induction 2 03-05-2014 06:39 PM
VA FS: , FA20club Turbo manifold, downpipe, dump, downpipe and intercooler (with pipi Ryan P Engine, Exhaust, Bolt-Ons 18 02-26-2014 07:08 PM
