Old 04-01-2018, 10:19 PM   #1
Open Loop
2013 FR-S Whiteout / SSC
Convert cigarette lighter to constant-powered?
Hi everyone. I would like to power a data recorder through the cigarette lighter in the center console, but I need it to constantly get power, even when key is in the off position. Has anyone done this or have an idea of how I can do this.
Alternatively, is there an ideal location in the center console or under the dash that has a wire that is constantly getting power from the battery?
Thank you in advance!
Open Loop is offline   Reply With Quote
Old 04-02-2018, 12:11 AM   #2
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
You could always wire it to the constant supply to the radio. That's probably the easiest place to route a wire from, and the easiest wire to get to. You could either wire it behind the radio, or run a wire from the radio to the cigarette outlet and wire it to that. If you are planning to wire it to the cig outlet, just remember to cut and cap off the accessory wire that powers it. If you tap in, all your accessories will run with the key off and drain your battery.
sharpsicle is offline   Reply With Quote
The Following User Says Thank You to sharpsicle For This Useful Post:
Open Loop (04-02-2018)
Old 04-02-2018, 12:54 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Power is switched by a relay with a signal from the ECU. Just replace the relay with a jumper. Link to manuals are in my sig line.
...edit: I remembered wrong. ACC1 relay switches the radio too. :|
Old 04-02-2018, 08:40 AM   #4
Open Loop
Thank you both. This sounds like a simple way to do it.
Old 04-02-2018, 08:42 AM   #5
Open Loop
Thank you both. The constant power line to the radio sounds like a simple way to do it.
Old 04-02-2018, 11:12 AM   #6
Chimera
Drives: FRS
add a fuse to the brake lights circuit can be used too, or a direct battery tap.
Few things I found out on the BRZ - extra cigarette lighter outlet 86design BRZ First-Gen (2012+) — General Topics 42 04-15-2023 12:56 AM
12v Cigarette Lighter Wire Color KenTK808 Electronics | Audio | NAV | Infotainment 2 05-18-2019 09:52 PM
Flush USB Cigarette Adapter Crispy517 CANADA 18 11-18-2014 06:43 PM
Cigarette Damage? Jac Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 09-09-2013 11:27 AM
Power Ports/ Cigarette Lighter Issues Tanuki Issues | Warranty | Recalls / TSB 6 11-21-2012 05:59 PM
