Old 07-05-2014, 08:07 PM   #113
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
for those who have issues with bumper fitment, I am selling the extra pair of quik mini latches that I purchased for my BRZ. I noticed that only one (instead of two) latch on each side is enough and looks better aesthetically
http://www.ft86club.com/forums/showt...29#post1831129
glamcem is offline   Reply With Quote
Old 07-30-2014, 01:50 AM   #114
Dipstik-sportech
Dipstik-sportech's Avatar
So I installed the quik latches on my car and it is way nicer now. I did find however not that the bumper is back where it should be that the clip behind the marker light doesn't line up anymore, has anyone else seen this? It's like the bumper is too far back and only half the hole is visible, I had to dremel the hole in the bumper to get the push clip to fit. Makes me wonder if the bumper is expanding in some way causing the clips under the headlight and at the fender to give out being as they're the weakest
Old 07-30-2014, 04:21 PM   #115
mister.bond
Drives: BRZ Subaru
I Have GOOD NEWS !!!!
The Problem is solved !!!
Without the Ugly looking Quik-Latch minis
My Subaru Dealer has done the Best Work i ever see for the Prob
but see at my Pictures !
So, the whole Problem is
that the Plastic from the Clips, the Plastic from the
whole Bumper is too Weak ! it is to flexible for holding the
Frontbumper in the right position.
In Fact when you drive the Frontbumper also produces Downforce !
And i have the STI Front Lip installed,
so i have much more downforce with that !
So, we take the car and modifiy the following parts as you can see in the pics :
This installation holds the Frontbumper in Place !
even wheni drive fast and the car produces downforce
the construction holds it solid in place !
And the best thing is : its not visible like the Quik-Latch minis
hope you like my Mod
mister.bond is offline   Reply With Quote
Old 07-30-2014, 04:25 PM   #116
Dipstik-sportech
A dealership did that!!? Wow I hope the documented that so they don't try to say you modified it yourself down the road. Neat idea I'd be interested to see how well it works long term. Its pretty bad that we have to use readi-rod or the latches to fix our bumpers that Subaru can't seem to fix
Old 10-09-2014, 11:40 AM   #117
Oakhenshield
Oakhenshield's Avatar
Drives: ahh its blue?
Originally Posted by digital_assassin View Post
I acquired a new bumper and still had this issue so I took it to the next level and completely cut off all the mounting tabs on the bumper and installed Quik-Latch minis. Problem solved for good.
just wondering do i need to drill a hole to the bumper?
Oakhenshield is offline   Reply With Quote
Old 10-21-2014, 02:45 AM   #118
luluma
luluma's Avatar
Drives: 2013 Scion FRS
Anybody fix this problem?
I went to the dealer and check all the new FRS sitting on the lot, 1/3 of then has this problem, and no one doing anything about it...
luluma is offline   Reply With Quote
Old 01-10-2015, 07:24 PM   #119
Oakhenshield
is this thread dead or still alive? because i want to bring up something..
i think i know whos the culprit for this issue..
i took off my bumper today to install something and tried to study why the bumper is loose, now i know some people here say that the one we need to fix is the bumper support with 3 bolts and i realized that this support holds the front not the sides and theres a separate part for that, its #12 in the front bumper diagram. i tried to move it and its loose even with the screw on
i havent tried to replace it yet and im not 100% sure but im gonna give it a try.
Bruuuum Bruuuum!
Old 04-19-2015, 09:50 PM   #120
elyugi1
Drives: raven black
Did you fix it??
elyugi1 is offline   Reply With Quote
Old 05-11-2015, 04:22 PM   #121
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
I love that it always is the driver side or both. Rarely does it seem to be just the pass. side
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 07-21-2015, 03:18 PM   #122
tyrantcf
Drives: '16 WRX, CBR1000RR
Mine I've just noticed is doing this on the passenger side only. Upon further examination one of the actual clips on the bumper (not the black plastic parts on the headlight bracket) is actually broken.
Fuuuuuuuuuhhhhh looks like quick latch minis for me. Are these hard to install on your own??
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 07-21-2015, 03:23 PM   #123
tyrantcf
And my bumper has never been off.
Old 07-21-2015, 04:02 PM   #124
Oakhenshield
i replaced the thing that i told about in my post months ago (taht thing still moves) but still cant fix it and now this time im pretty sure that something beside the headlight and behind the fender is broken i just dont know what it is and i cant strip my car because i live in an apartment and doesnt have a proper place to work on it
its behind this part
http://www.villagescionparts.com/sho...g=front+bumper "52115D/52116D" depends on which side is coming off
Bruuuum Bruuuum!
Old 08-12-2015, 12:48 PM   #125
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
So can anyone confirm that if I spend $50 on these 2 harnesses that the problem will be solved?
http://www.subarupartsamerica.com/pa...rner%20support
Part numbers:
57707CA001 - Corner support
Right
57707CA011 - Corner support
Left
Benschneider06 is offline   Reply With Quote
Old 08-12-2015, 01:05 PM   #126
Benschneider06
My problem is getting severe
Search this Thread:
Advanced Search
Front Bumper Black Vinyl Juanito08 Exterior Parts (Aero, Lighting, Etc.) 37 09-18-2015 05:09 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) -- General Topics 29 08-14-2012 01:19 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 04:30 PM
BRZ to FR-S front bumper swap? r4m3n Cosmetic Modification (Interior/Exterior/Lighting) 4 04-20-2012 06:29 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 03:24 AM
