Old 08-12-2015, 03:04 PM   #127
dj2020
Originally Posted by Benschneider06 View Post
So can anyone confirm that if I spend $50 on these 2 harnesses that the problem will be solved?
http://www.subarupartsamerica.com/pa...rner%20support
Part numbers:
57707CA001 - Corner support
Right
57707CA011 - Corner support
Left
I installed two new corner supports from above and it did NOT fix the problem for me.
dj2020 is offline   Reply With Quote
Old 08-12-2015, 03:05 PM   #128
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
God damnit........
So... so far no one has found a DIY fix for this?
Benschneider06 is offline   Reply With Quote
Old 08-12-2015, 03:14 PM   #129
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
God damnit........
I would say the Mini Quick Latches are a DIY fix for it, but i'm guessing you want a completely stock solution that does not require drilling.
I think my issue is more sever than any of you that have posted. I'll have to get some pics to show. It's ridiculous. I'm actually considering going the quick mini latches route.
blackfireball5 is offline   Reply With Quote
Old 08-12-2015, 04:18 PM   #130
Benschneider06
Yeah.... there is no reason we should have to drill holes in our bumper because Subaru and Toyota don't have their shit together.
Old 08-12-2015, 04:22 PM   #131
Benschneider06
Question
Originally Posted by charged86 View Post
Im about to find out tomorrow I bought them at Subaru.
Did you ever have any luck after installing those new brackets??
Old 08-12-2015, 05:39 PM   #132
blackfireball5
True. But Toyota would probably never fix my issue since I have a trd front lip and they'd probably say it's because of that.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 08-12-2015, 07:03 PM   #133
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
has anyone tried 3m tape? Or I had a Saab Viggen that used to scrape on everything and I used what was basically zip ties behind it to hold the bumper up, it looked totally stock from the front until they broke every few months.
Old 08-12-2015, 11:37 PM   #134
Kwise1
Kwise1's Avatar
Drives: Raven FRS
I had this problem when the bumper wasn't aligned properly in the headlight bracket. It has to sit in the slot of the headlight bracket not on top of it.
Kwise1 is offline   Reply With Quote
Old 08-12-2015, 11:43 PM   #135
Kwise1
Kwise1's Avatar
Drives: Raven FRS
And #12 in that diagram will also help since the tab on that piece wears down over time and won't allow the bumper to clip on tight
Old 08-13-2015, 06:21 PM   #136
636
636's Avatar
Drives: '23 CWP BRZ
Not really helpful, but my INGS +1 bumper fits insanely snug. Literally there is no gap at all.
With my stock bumper, I have this problem. I've just gotten used to it, and push it in everytime I see it, lol
636 is offline   Reply With Quote
Old 08-13-2015, 10:43 PM   #137
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
Have any of you considered the solution on page 6 by mister.bond? He says it is fixed and hidden for him.
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
Old 08-14-2015, 12:37 AM   #138
blackfireball5
I wonder if his mod would work with my full blown turbo kit. Maybe we try that? Idk.
Wheelwell Profile
The Following User Says Thank You to blackfireball5 For This Useful Post:
AreteAuto (08-17-2015)
Old 12-09-2015, 11:14 PM   #139
hernandoco
hernandoco's Avatar
Sorry to revive this thread but yea... Here's a pic of mine.
I'm planning to thicken the tabs with some jb weld type of material. It's a pretty hard epoxy and it sticks pretty well to plastic. So basically doing the speaker wire method but instead of speaker wire, I'm using an epoxy to build up the tabs thus hopefully clinging on to the bumper better.
hernandoco is offline   Reply With Quote
Old 01-16-2016, 10:49 PM   #140
raptorhunter89
Drives: 2013 Subaru BRZ
i'd like to see how you do this.
Took my sag to the Subaru dealer near me and said because there are scrapes on the bottom of the bumper that warranty/tsb is not applicable. Bummer, roads around here are pretty bad, scrape the bumper just on bad humps and crossing roads time to time.
Edit: For clarification, i am completely stock, stock height.
raptorhunter89 is offline   Reply With Quote
Search this Thread:
Advanced Search
Front Bumper Black Vinyl Juanito08 Exterior Parts (Aero, Lighting, Etc.) 37 09-18-2015 05:09 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) -- General Topics 29 08-14-2012 01:19 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 04:30 PM
BRZ to FR-S front bumper swap? r4m3n Cosmetic Modification (Interior/Exterior/Lighting) 4 04-20-2012 06:29 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 03:24 AM
