#16 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (07-27-2019), Yoshoobaroo (07-27-2019) |
#18 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Quite simple...there are only two choices for best short shifter I'm aware of: CAE Ultra shifter or the IRP shifter. Both are of similar design and entirely replace the factory setup unlike every other shifter out there - no rubber bushings anywhere in them. Direct, solid connections with ZERO play and one of the most satisfying shifting feel you'll ever get. Plus you get short throw with longer lever that puts the shifter at a more ideal height than most factory shifters. Of course with these you are talking $$$$...especially for the CAE Ultra shifter.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#19 | |
Drives: FR-S,GTI
| The Following User Says Thank You to WNDSRFR For This Useful Post: | humfrz (07-27-2019) |
#20 |
Shorter throw than stock even with the longer lever...
#21 |
Drives: Looking to buy
What would be the best shifter that is not like the IRP/CAE? Looking for something that is like stock form but have shorter throw and no rattle. There were other options like the TRD quick shifter but there were reviews where you need to go back and check on it every once in a while because it came come loose which is something that I definitely do not want to do and waste my time on. The FT86SF short shifter option has a rattling noise that people says it has in higher rpm/gears. So it seems like there are always some kind of drawbacks...
Sent from my GM1915 using Tapatalk |
#22 |
Drives: Bone stock
Raceseng makes an adapter that connects the reverse lockout to make it longer.
Sent from my SM-N960U using Tapatalk |
#23 |
#24 | |
| The Following User Says Thank You to Vracer111 For This Useful Post: | humfrz (07-27-2019) |
#25 | |
Now on my Nissan Frontier I absolutely want the PRG Racing short throw shifter....way too much movement of entire arm required for stock, a little too much reach for the forward gears - ain't no shifting with the wrist movement.
#26 | |
Only happy when it rains.
Drives: series.blue
Go to 1:15 or so |
#27 | |
![]() As far as feeling better, maybe that's because many new drivers are used to the feel of the toggle things on game controllers? - ![]() As far as miss-shifting, it would seem to me that the closer the shift positions are the less margin of error there is, thus more of a chance of miss shifting. Hell, in my old 1937 Chev pickup with a floorboard shifter, second gear was anywhere from pointing the shifter towards the speedometer all the way over to the glovebox - ![]() ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (07-27-2019) |
#28 | |
fabulous
They feel cooler. That's all.
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 10:57 PM |
| TRD Short Shifter | FNCrazy | Engine, Exhaust, Transmission | 22 | 07-02-2016 01:58 PM |
| cae ultra shifter vs short shifter | jdmblood | Engine, Exhaust, Transmission | 22 | 01-14-2016 12:19 AM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
| TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 02:24 AM |
