#1079 |
Drives: RX-7 / BRZ
The thickness of the stakes in that diffuser throw off the scale? Is it a durability concern?
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#1080 |
Drives: GR Corolla
Quite possibly. If I do hit a wall, it is usually the rear. I believe it's actual function is ballast bearing. I know just the additional weight by itself has made the car feel more controllable for me. I might experiment with finding various things I can tape down on it. haha.
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | soundman98 (09-25-2021) |
#1081 |
ProCrastinationConsultant
could file down the sides at an angle so the edges finished surface appears thinner
| The Following User Says Thank You to soundman98 For This Useful Post: | Kaotic Lazagna (09-25-2021) |
#1082 |
Drives: GR Corolla
#1083 |
Drives: GR Corolla
Update for those that care about the RC cars. LOL. I moved the motor from the bottom mount, to the top mount. Did a very quick test run, and it's much more controllable. I guess I'm one of those that prefer higher center of gravity for drifting.
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | soundman98 (10-01-2021) |
#1084 |
Drives: GR Corolla
Had some time to try to polish the EVO6 today. Not sure why, but this one had more orange peel than the rest. Maybe I should have started wet sanding with 2000 grit instead of 2500. Oh well, it's decent enough. I'll get around to waxing it and finish building it....eventually. lol
#1085 |
Drives: GR Corolla
Lowered the EVO6. BUT, looks like I can't use the wheels I got for it (Work CR2P). Offset is too aggressive. I know it's sacrilegious, but looks like I'll have to use the Nismo wheels from the R32 kit. I actually like the white, so maybe I'll just throw on some clear over it.
#1086 |
Drives: GR Corolla
I also gotta figure out why there is so much toe out in the rear.
#1087 |
Drives: GR Corolla
Might be able to get these 18" AVS Model 5 wheels to work as well. Their offset will be in between the Nismo and the Works. Since I'll be placing the EVO with the Chaser and Crown (lumping the sedans together in the display case), the AVS wheels might make it look more in place. Yes, yes, I know, the EVO isn't a VIP build/car.
What do you guys think? |
#1088 |
Split spokes have always looked good to me
| The Following User Says Thank You to soundman98 For This Useful Post: | Kaotic Lazagna (10-19-2021) |
#1089 |
Drives: 2010 corolla
#1090 |
#1091 |
LMGTFY
Drives: 13 FRS, 91 Miata
That E-Brake is bugging the hell outta me.
#1092 |
Drives: GR Corolla
For those that liked to order their Tamiya products from Hobby Search (Japan), they pulled all Tamiya products out and will no longer sell Tamiya.
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 08:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 12:11 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 11:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 02:02 PM |
