Old 06-03-2021, 09:31 PM   #1023
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Am I posting this in the right thread?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post:
JD001 (06-05-2021), Spuds (06-03-2021), x808drifter (06-04-2021)
Old 06-04-2021, 10:54 AM   #1024
Attachment 201481
Only if you made the condom hat with your own two hands.
Dadhawk (06-16-2021)
Old 06-04-2021, 12:20 PM   #1025
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I thought it looked more like a baby bottle nipple.
Old 06-15-2021, 09:09 PM   #1026
Kaotic Lazagna
Drives: GR Corolla
Alright, between working OT and working on the R32 (real one), I finally got around to the LEDs for the Chaser. Experimented with using warm white LEDs for the taillights since for what ever reason, if I use red LEDs on the same 2 positive post battery holder, only either the headlights or the taillights can be on at one time. With the warm white, I can have both the headlights and taillights on at the same time. Using only Elmer's white glue for the lenses, so hopefully they stick. Decided to not do any high beams again.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Dadhawk (06-15-2021), NoHaveMSG (06-15-2021)
Old 06-15-2021, 10:32 PM   #1027
soundman98
ProCrastinationConsultant
soundman98's Avatar
what? this makes no sense.. white led's are 3.2v ea. red led's are 1.9v ea... you should be able to run twice the amount of red led's over white...
what's your series/parallel wiring looking like?
Old 06-16-2021, 06:43 AM   #1028
Kaotic Lazagna
Drives: GR Corolla
Yeah, I don't get it either. I'm using a 2032 battery holder that has 2 positive terminals and 1 negative. The switch is a 4 channel switch.
So for the taillights, I have 4 LEDs with the positive wires leading to one wire that goes to the switch (channel 2), and then goes to the positive terminal of the battery holder. The negative wires lead to one wire that goes to the negative on the battery holder.
The headlights are wired the same way with the 2 LEDs. Positive wires lead to one wire that goes to channel 1 of the switch, and then goes to the other positive terminal. The negative goes to the same negative.
If I do the exact same set up as that with red LEDs for the taillights (which I did for the R33 and the Crown, the R34 I used two batteries and holders), I have that issue I mentioned earlier. Any idea on what's going on/what I'm doing wrong?
Old 06-16-2021, 05:22 PM   #1029
soundman98
soundman98's Avatar
try connecting series/parallel. of the 4 red led's at the back, split them into 2 groups.
connect the first group's first led positive wire to the positive wire from the switch. connect the negative of that led to the positive of the 2nd led, and then connect the negative of the 2nd led to the negative wire going back to the battery.
i suspect that all of the led's in parallel with the way you've wired them, you're reaching the limits of a cr2032 setup, as the voltage of a single 2032 works out ok, but it might be attempting to distribute too much of it across too many different area's.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Kaotic Lazagna (06-16-2021), Ultramaroon (06-16-2021)
Old 06-16-2021, 07:21 PM   #1030
Ultramaroon
fabulous
Ultramaroon's Avatar
Spuds (06-16-2021)
Old 06-16-2021, 08:16 PM   #1031
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
African or European
soundman98 (06-16-2021), Ultramaroon (06-16-2021)
Old 06-16-2021, 08:25 PM   #1032
Sapphireho
Connection issues
Sapphireho's Avatar
Attachment 201481
Best laugh in a while.
100% right thread.
FR-S2GT86 (06-17-2021)
Old 06-16-2021, 09:15 PM   #1033
Kaotic Lazagna
Drives: GR Corolla
Would I put both groups to the same positive terminal and same channel on the switch?
I could always do what I did with the R34 and use two batteries and two holders. haha
Old 06-16-2021, 10:00 PM   #1034
Ultramaroon
fabulous
Old 06-16-2021, 10:19 PM   #1035
soundman98
soundman98's Avatar
keep everything else as you had it. the rear lights on channel 2, the front lights on channel 1.
Kaotic Lazagna (06-17-2021)
Old 06-16-2021, 10:42 PM   #1036
Watt is the internal resistance
soundman98 (06-16-2021), Ultramaroon (06-17-2021)
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 08:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 12:11 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 02:02 PM
