#939 |
Drives: RX-7 / BRZ
I'm aware of the product. I have 4-5 different finishes on hand. I don't think mine is 6"x11 though. Bare Metal Foil i the brand with a 55(?) chevy on the front. They have them at the local hobbytown.
I much prefer Hasegawa's Tryfinish films, personally speaking. I keep their Hologram film instock at all times which is the same thing but had a reflective prismatic finish similar to a rainbow reflecting in oil slick for placing over camera lens effects and even headlights. It's not very useful in scale modeling outside of gunpla and sci-fi though. Kinda similar to the aurora films. https://www.hlj.com/hologram-finish-sheet-hsgtf14 https://www.hlj.com/duralumin-finish-hsgtf2
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | Tcoat (05-11-2021) |
#940 | |
https://www.hlj.com/top-shade-finish-green-hsgtf930
#941 |
Drives: RX-7 / BRZ
I haven't used it. It's also very rare for me to even work on a car old enough to have a green windshield tint.
I tend to use Tamiya's acrylic paints for clear colors. I hated them until I figured out a few tricks to making them work better. 1. MR. Color Resin Primer. It is a clear primer for garage kits but a nice base for clear plastics (coat inside of glass) without the risk of having to sand them. 2. Think the Tamiya paints with AK Real Colors' High Compatibility thinner. For whatever reason it does a better job of breaking up the pigments which tend to ruin a transparent finish. 3. I also dip my canopies instead of spray them with a urethane clear afterwards. I used to dip them to color them also (future+clear paints) but the result was usually less than stellar. It's been a while since I did a canopy but the last one I did was on some 1/72 Macross kits.
| The Following 3 Users Say Thank You to Kiske For This Useful Post: |
#942 | |
#943 |
Wes
Been slowly working on this V1 Rocket Bunny with a 2JZ swap. Just settled on the wheels (Work VS-TX in matte gunmetal). Painted in Honda Phoenix Yellow
![]() Carbon trans tunnel cover with "suede" shifter and ebrake boot + knob, dash mounted gauge pod and Bride Zeta 3 seats. Some JDM red checkered floor mats as well. Deep dish steering wheel with quick release hub. ![]() ![]() Heat wrapped the turbo manifold ![]() 2JZ even has separate ignition coils ![]() Will post when it's done (in 2025 lol) And here is a tasty Z tune painted midnight purple III with bronze TE37 cause why not!
Instagram: @gt86ws
| The Following 8 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: | Dadhawk (05-12-2021), JD001 (05-13-2021), Kaotic Lazagna (05-12-2021), NoHaveMSG (05-12-2021), soundman98 (05-12-2021), Spuds (05-12-2021), Tcoat (05-12-2021), wolffbite (05-17-2021) |
#944 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | StraightOuttaCanadaEh (05-12-2021) |
#945 |
Drives: GR Corolla
Picked up some Milliput to try out on filling gaps. Rather messy, but seems better than the Tamiya putty I've used in the pass. Didn't exactly fill the rear bumper gap that well, but better than before.
Also cut up some styrene and made a simple rear spoiler since this kit doesn't come with one. |
#946 |
Wes
People in the hobby that I know actually just use automotive bondo. Cheaper and easier to work with than these expensive hobby putties. Haven't tried myself but seen the results
Instagram: @gt86ws
| The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: | Dadhawk (05-13-2021), Kaotic Lazagna (05-13-2021) |
#947 | |
Drives: GR Corolla
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | StraightOuttaCanadaEh (05-13-2021) |
#948 | ||
![]() Pretty much just settled on using the Tamiya stuff over the years since it is designed for use with plastic. It is funny you hate the Aoshima kits so much. I actually prefer them over the Tamiya ones and they are 1000 times better than the old school American company car kits. Mind you I have only built the one BRZ so far.
#949 |
Drives: 2014 Zenki 37J
Agree with Tcoat with regards to bondo. Putty meant for hobby/plastic use is safer to usefor plastic models kits. Tamiya putties usually gives excellent results, but they have different types of putties for different jobs. Most people make the mistake of just going for their basic white putty in a tube, because it's readily available and cheap, but that's just really only good for filling tiny holds. For filling larger gaps, Tamiya's polyester putty does a better job. And for bodykits or major modifications, they have 2 part epoxy putties.
Aoshima is another whole can of worms. Anything they've newly designed and produced in the last 10 or so years are almost as good at Tamiya. Everything else before that or re-release in a new box (pretending to be a new design) are horrible for fit and finish. The Chaser is, unfortunately, the latter. |
#950 |
Wes
yeah you might be right. My circle of modding peeps deal exclusively in 1/18 scale, which is mostly diecast metal, recently with some plastic being introduced. The bumpers, where most of the work is being done, are 99 times out of 100 plastic though, but it might be a different type of plastic from Tamiya kits and such.
Instagram: @gt86ws
#951 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | StraightOuttaCanadaEh (05-13-2021) |
#952 | ||
Drives: GR Corolla
I don't necessarily hate Aoshima. I like how they have modded models from the box. Just the fit and finish hasn't been that good for me. Then again, the Rojam Crown and this Vertex Chaser are either discontinued or re releases. Same for the Rodextyle S15, so I'm already expecting some issues with that one too. |
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 08:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 12:11 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 11:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 02:02 PM |
