Old 05-07-2021, 08:30 AM   #897
Just hope the 'before' and 'after' colours match....
Read further down!
A lot of the colour discrepancy you see here is from the difference in how the pictures were taken or edited.
I suck at the pictures so the colours always look a little dark.
Old 05-08-2021, 02:13 PM   #898
OK aircraft is 99.9% done. It will still get some mud and grass stuck to it once I do the base up. Waiting on a nice shiny new static grass applicator to show up so I can do the base up properly. Will build the scrap pile (crushed scoop, bottom panels, etc.) and get into the diorama once ready to get at it again.
For reference:
The Following 12 Users Say Thank You to Tcoat For This Useful Post:
bcj (05-08-2021), Dadhawk (05-08-2021), JD001 (05-08-2021), Kaotic Lazagna (05-08-2021), MICHAEL450f (05-08-2021), Nails (05-10-2021), NoHaveMSG (05-09-2021), pope (05-08-2021), soundman98 (05-08-2021), Spuds (05-08-2021), Ultramaroon (05-08-2021), weederr33 (05-09-2021)
Old 05-08-2021, 07:31 PM   #899
Kaotic Lazagna
Drives: GR Corolla
Jaw drops with every progress update!
The Following 4 Users Say Thank You to Kaotic Lazagna For This Useful Post:
JD001 (05-09-2021), soundman98 (05-08-2021), Tcoat (05-09-2021), Ultramaroon (05-08-2021)
Old 05-08-2021, 07:53 PM   #900
Ultramaroon
fabulous
Ultramaroon's Avatar
^^100% this^^^
Had to stop and show Mrs. Ultra all the pics. @Tcoat, you are an artist.
Old 05-08-2021, 09:16 PM   #901
Kaotic Lazagna
Drives: GR Corolla
Hood cut out of the Chaser. Added a rod to help support the body, and have a place where the hood can sit back on.
Now onto cutting out the flat taillight portion (Aoshima really cheaped out here) and install some 3D printed reflectors.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
soundman98 (05-08-2021), Tcoat (05-08-2021)
Old 05-09-2021, 12:31 PM   #902
Stephen W.
Stephen W.'s Avatar
Drives: 2018 CBS BRZ tS
Same kit. The cockpit is still packed for painting.
The period he is painting it for the plane was only about 3 weeks old so would be much cleaner than when it was crashed at a whopping 7 weeks old!
We even used the same paints so the base colours are identical and the difference is all in the degree of weathering. He also used the earlier version of the kill mark banner with fewer kills than my version. The kit had both thank goodness.
Ah, aren't those mission markings?
It's my understanding that Dominic 'Don' Gentile was only credited with 7 1/2 of his 21 kills in this aircraft.
Old 05-09-2021, 01:44 PM   #903
Kaotic Lazagna
Drives: GR Corolla
LH side done (not glued in yet). Much better than just the blank from factory on the RH side. Drilled holes in prep for lights.
Old 05-09-2021, 02:45 PM   #904
JD001
JD001's Avatar
Drives: Subaru BRZ
^^100% this^^^
I've been doing the same.. my wife loves the commitment to detail.. down to bits that are never seen..
The Following User Says Thank You to JD001 For This Useful Post:
Ultramaroon (05-09-2021)
Old 05-09-2021, 02:52 PM   #905
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
For reference:
Jesus this just boggles my mind at how you can get this so detailed!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 05-09-2021, 04:01 PM   #906
1st86 Driver!
And now back to the "plastic modelling for us mere mortals" segment....
Finally got the missing piece from the Halo Energy Sword (mentioned in this post) in the mail, only took three weeks to get the part, and 45 minutes to finish the sword (below). It is right at 24" long.
Can you swing it around?
Actually, you can hold it by the handle and move it around non-aggressively, but I suspect if you bump something it will fall apart. The only portion that isn't relatively solid are the top supports on the stand. They pretty much come apart if you move it at all once in the stand, including taking it off.
The Following 6 Users Say Thank You to Dadhawk For This Useful Post:
JD001 (05-09-2021), Kaotic Lazagna (05-09-2021), NoHaveMSG (05-09-2021), Spuds (05-09-2021), Tcoat (05-09-2021), Ultramaroon (05-10-2021)
Old 05-09-2021, 04:42 PM   #907
No they are kills. He marked 6 ground kills as well as the aerial ones. It caused quite the controversy at the time. He only few 11 missions in the P-51.
"On April 5, 1944, Gentile claimed his 27th enemy planes destroyed, thus breaking Eddie Rickenbacker's WWI record of 26. (At the time the Eighth Air Force recognized ground kills as part of a pilots score, in part because strafing missions were felt to be least as dangerous, if not more so, than aerial combat. Seven of Gentile's destroyed aircraft were on ground kills.) Three days later, on April 8, Gentile downed three more planes, raising his total to 30. Gentile was credited with 21+ air victories. He scored two kills with the RAF in the Spitfire, 4.33 kills in the P-47 Thunderbolt, and 15.5 kills in the P-51B Mustang. He made half of his claims in March 1944, flying over the skies of Germany."
http://acepilots.com/usaaf_gentile.html
Dadhawk (05-09-2021), soundman98 (05-09-2021), Spuds (05-09-2021)
Old 05-09-2021, 05:17 PM   #908
Well if you are ever near Old Buckenham you could go see it in person.
JD001 (05-10-2021), Ultramaroon (05-10-2021)
Old 05-09-2021, 06:15 PM   #909
Stephen W.
Stephen W.'s Avatar
My bad. Serves me right for believing the internet.
http://www.americanairmuseum.com/aircraft/18316
... Olive Drab with Natural Grey undersurfaces, white quick identification marking (QIM) tail and wing bands. Red nose with white spinner (the spinner was later also painted red) and red and white chequerboard along the length of the exhausts. 'Shangri-La' written in white beneath the 'Boxing Cock' Eagle insignia of the 4th Fighter Group on yellow background and mission markings drawn on a white scroll on the front edge of cockpit on the port side. Coded (VF-T).
Assigned to 336FS, 4FG, 8AF USAAF. Personal aircraft of Dominic 'Don' Gentile. He claimed 7.5 of his 21 victories in this aircraft. Don Gentile crashed this A/C whilst displaying to reporters after his final mission at his home base Debden on 13-Apr-44.
The Following User Says Thank You to Stephen W. For This Useful Post:
Tcoat (05-09-2021)
Old 05-09-2021, 06:21 PM   #910
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is some unreal work @Tcoat
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Tcoat (05-09-2021)
Search this Thread:
Advanced Search
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 08:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 12:11 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 02:02 PM
