86WORX
Old 03-07-2021, 09:53 PM   #533
Kaotic Lazagna
Drives: GR Corolla
need to keep sanding, adding filler, and more sanding. really a pain.
But if I add more filler, it will no longer be flush with the body.
Kaotic Lazagna is online now   Reply With Quote
Old 03-07-2021, 09:57 PM   #534
Kaotic Lazagna
Drives: GR Corolla
So this is what it looks like. I guess I missed that tiny hole, or a chunk of putty came off when I was sanding???
Old 03-07-2021, 09:58 PM   #535
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Is the area you placed in too high (sand more) or too low (add filler)? Remember you should be samding before amd after applying fillers and primer to have a better bond and finish.
The Following User Says Thank You to Kiske For This Useful Post:
soundman98 (03-07-2021)
Old 03-07-2021, 10:03 PM   #536
Kaotic Lazagna
Drives: GR Corolla
For the most part, they're flush with the rest of the roof (my nail does not catch on the front and back sections). It's only the sides that aren't super flush since I didn't want to sand away the rain channel on the side. But that doesn't show as bad as the front and back.
I did sand before and after the filler, and even sanded it down more after the gray primer.
Old 03-07-2021, 10:05 PM   #537
Kaotic Lazagna
Drives: GR Corolla
Sanded down with 320 grit, then when it was near the roof line, sanded down with 800, then 1500, then 2000, and finished with toothpaste.
Edit: I should clarify that's what I did prior to spraying the gray primer, and again before the white primer.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Tcoat (03-08-2021)
Old 03-08-2021, 08:29 AM   #538
Fill and sand. Fill and sand. Fill and sand.
Or just cover it up with something that hides it.
Kaotic Lazagna (03-08-2021), soundman98 (03-08-2021)
Old 03-08-2021, 11:09 AM   #539
Kaotic Lazagna
Drives: GR Corolla
Will be one fancy pizza delivery vehicle. Hahaha
Dadhawk (03-08-2021)
Old 03-08-2021, 11:14 AM   #540
Times are tuff!
Dadhawk (03-08-2021), Kaotic Lazagna (03-08-2021), soundman98 (03-08-2021)
Old 03-08-2021, 02:51 PM   #541
JD001
JD001's Avatar
Drives: Subaru BRZ
Did you fill in the sunroof? Greater torsional rigidity..
The Following 4 Users Say Thank You to JD001 For This Useful Post:
Kaotic Lazagna (03-08-2021), soundman98 (03-08-2021), Tcoat (03-08-2021), Ultramaroon (03-08-2021)
Old 03-08-2021, 03:37 PM   #542
Kaotic Lazagna
Drives: GR Corolla
Old 03-09-2021, 12:11 PM   #543
Teaser
Dadhawk (03-09-2021), Kaotic Lazagna (03-09-2021), NoHaveMSG (03-09-2021)
Old 03-09-2021, 12:15 PM   #544
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Did the alternator catch on the frame when you hoisted it out?
Don't think the belts line up now.
Old 03-09-2021, 12:18 PM   #545
I did have it in and out many times (both the real thing and the model).
It was straightened up before it was glued in.
bcj (03-09-2021), soundman98 (03-10-2021)
Old 03-09-2021, 12:20 PM   #546
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
The model or the real one?
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
bcj (03-09-2021), Spuds (03-09-2021), Ultramaroon (03-09-2021)
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 08:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 12:11 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 02:02 PM
