#323 |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#324 |
Drives: GR Corolla
Trying out panel accent lines. Doesn't come off as easy as I thought it would. Remaining paint that didn't come off with the thinner came off with some polish.
Makes me want to do the R33 now instead of waiting. LOL. |
#325 |
The Dictater
Drives: '13 Red Scion FRS
Could try using an ink wash instead of paint. Not sure how messy that would be for your purpose, but it's used for darkening shadowed folds on mini figures.
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Dadhawk (11-14-2020), Kaotic Lazagna (11-14-2020) |
#326 |
Drives: GR Corolla
I believe this is considered a wash by Tamiya??? It's specifically their panel accent line, line. Haha. I could also just be waiting too long for it to dry before removing excess.
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Spuds (11-14-2020) |
#327 |
I use a very fine marker for that sort of panel line. Can get them at any art supply store. I find the panel was to heavy and it gives sort of a comic book outline look.
| The Following User Says Thank You to Tcoat For This Useful Post: | Kaotic Lazagna (11-14-2020) |
#328 |
Drives: GR Corolla
I think it depends on how much paint you leave on the brush or how many layers you put on? I like the outcome for the most part. haha. Although I think some of my lines are a little too dark from having too much paint. oh well.
#329 | |
The Dictater
Edit:. Still looks pretty good for the most part. I like the result more than what you started with. I don't mean that it's not good how you did it. Last edited by Spuds; 11-14-2020 at 10:11 PM. |
| The Following User Says Thank You to Spuds For This Useful Post: | Kaotic Lazagna (11-14-2020) |
#330 |
I like to try to keep things in scale whenever possible so don't like too thick line. Go stand back from a car until it appears about the same size as the model at 2 feet away. Check out what you can see. The panel lines should be almost invisible. In scale the panel lines with the wash in them would be about an inch wide on he full size car.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Kaotic Lazagna (11-14-2020), Spuds (11-15-2020) |
#331 | ||
Drives: GR Corolla
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Spuds (11-15-2020) |
#332 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Kaotic Lazagna (11-15-2020), Spuds (11-15-2020) |
#333 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Kotobukiya HMM Zoids Death Stinger! I'll probably order 1 last model kit (the Geno Breaker) then I might graduate and actually start the Leopard II tank I have collecting dust!
| The Following 4 Users Say Thank You to weederr33 For This Useful Post: |
#334 | |
Drives: RX-7 / BRZ
Best way to do that is to get into 2 practices. 1. Re-engrave panel lines before painting using a scribe or needle. This makes them a bit crisper, deeper and allows you to do more paint work without fear of filling the cavity. If you ever build a Hasegawa or resin garage kits you need to take this to heart. 2. Mixing your own panel washes. Ideally pure black creates too much contrast when going for scale. Mixing a color that is a darker shade similar to to body color will really help. This is pretty common on aircraft modeling where modelers mix a darker grey than the one they painted with. The Tamiya panel line accent washes are just pre-thinned enamel paints. You can thin enamels with thinner or using a much cheaper lighter fluid. You want it runny enough to flow into the panel lines but, not too thinned that your wash creates uneven shades. I personally use the cheap Testors enamel paints to mix up shades when Tamiya's washes don't suffice.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following 3 Users Say Thank You to Kiske For This Useful Post: |
#335 | |
For panel lines and highlighting detail I exclusively use an invention of my own. I mix some black acrylic painters paint (the kind in a tube) with Future acrylic floor wax until it is just barely translucent. I then cover the whole model with this mix. The self leveling properties of the Future make it settle into panel lines and around detail. The raised surfaces only take on a slight tint that can be wiped off using a cloth dipped in clean Future if you want. I am usually looking for a weathered surface so I make it streaky instead. It works very very well if decals are going on and I just spray it clear flat to get rid of the gloss. I have never ever seen this method in any of my magazines or online but it is extremely effective. You can really see the effect with the Bandai kits since they have massive detail that just disappears in monochrome paint.
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | BigHugeFatGuy (11-15-2020), Dadhawk (11-15-2020), JD001 (11-15-2020), Kaotic Lazagna (11-15-2020), spike021 (11-15-2020), Spuds (11-15-2020) |
#336 |
Drives: GR Corolla
That method looks like it works well for those types of models. Would look good on the undercarriage of a car model too!
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 08:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 12:11 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 11:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 02:02 PM |
