Old 03-18-2018, 12:14 PM   #1
Levi989
Drives: black
Lexus credit card smart key compatibility
I was wondering if anyone has reprogrammed a lexus slim credit card key shown below to work with their BRZ limited. This is a common modification on Priuschat and by my research atleast the 2014 BRZ Limited has the same FCC ID as the Prius so theoretically that means this key fob swap could work on a BRZ Limited as well.
Link to info on Lexus credit card key swap for a prius:
https://priuschat.com/threads/info-s...rt-key.163328/
Pics from the above thread:
BRZ/FRS FCC IDs:
https://www.joomag.com/Frontend/WebS...43001386910946
2014 MY:
For vehicles sold in the U.S.A.
FCC ID: HYQ23AAE
FCC ID: HYQ14ACX
FCC ID: Y8PSSPLF03
The bolded/underlined FCC ID has been tested to work with the lexus smart keys so I assume if that FCC ID works for the prius to convert to a smart key then it should work for a BRZ Limited as well.
I did find this in searching, stating that the key fob would need to be "re-seeded" which is a process described in the prius chat thread. I think if you buy the new smart key brand new you don't need to "re-seed" it, that process only applies to used key fobs/smart keys.
http://www.ft86club.com/forums/showp...30&postcount=2
Has anyone done this key fob swap? I think it would be much more convenient to have the key fob be a credit card in your wallet instead of the much bulkier oem keyfob.
Levi989 is offline   Reply With Quote
Old 03-18-2018, 07:47 PM   #2
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i am going to try it!
Surok is offline   Reply With Quote
Old 03-20-2018, 01:12 PM   #3
Kordless
Drives: '13 BRZ Limited
Following. I'd like to know as I have a 2013 and I hate carrying the thick key.
This would be a very useful feature.
2019 Mazda MX-5 RF
2013 Subaru BRZ - SOLD
Instagram - @uwuboiz
Kordless is offline   Reply With Quote
Old 10-31-2018, 05:41 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Anyone have any updates to this? Someone on FB suggested it would work...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 12-06-2018, 11:49 AM   #5
bentleyboii
bentleyboii's Avatar
Drives: 2022 GR86
I am Interested as well!
@Surok Did you ever do this?
bentleyboii is offline   Reply With Quote
Old 01-24-2019, 12:40 AM   #6
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
no i didnt! so sorry.
Old 06-14-2022, 02:43 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm going to bump this. Has anyone done this successfully who can illustrate the process here. I would like to lose the bulky fob and just have a card in the wallet and a slim key backup on the keychain.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Jdmjunkie (06-14-2022)
Old 06-14-2022, 05:13 PM   #8
Irace86.2.0
Apparently the FCC ID HYQ14AEB wallet card works for the HYQ14ACX ID per many forums. I just wonder if it is possible to easily reprogram a used card. I can't see spending $250+ for a new card, plus whatever else is potentially needed. I have Techstream, so I can possibly do this myself.
Old 06-21-2022, 05:05 PM   #9
Irace86.2.0
That is the part number: 89994-48142.
I'm still waiting for a used one to pop up online.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
norcalpb (06-21-2022), Petah78 (06-22-2022)
Old 06-27-2022, 07:57 PM   #10
geraldjust
Drives: MR2, Sliver BRZ
If you have an FRS or GT 86 there is a chance. But if you have a BRZ most likely it will not work. Since these work similar to keyless entry. They have a specific area in the data that is in the keys that tells it it's a difference between Subaru, Toyota. and the certification ecu also has that distinction.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
The Following User Says Thank You to geraldjust For This Useful Post:
Irace86.2.0 (06-28-2022)
Old 06-28-2022, 12:47 AM   #11
Irace86.2.0
I see, but I don’t think that matters because the system is probably Toyota’s. I say that because my car still uses the full Techstream with key reset functions.
Old 06-29-2022, 04:16 AM   #12
geraldjust
Yeah I will usually allows you to get up to the key functions but when you actually try to erase most people get an error. I guess it is more dependent on the year of the car. 13-14 have the older style / transponders. and 15-16 have the next gen keys. But it will not allow you to register a smart key thats not meant from a toyota/brz around. I believe its on the P1 data field in the key. ive tried changing it but no luck unfortunately.
edit: oh plus you will have to virginize a used key because it carries the vehicle ID number and the key itself too.
Old 06-29-2022, 12:42 PM   #13
Irace86.2.0
I was either planning to buy a new one, an unlocked one, or pay $20 to unlock it.
Old 04-04-2023, 03:32 PM   #14
aslamkhan
Drives: Subaru max
I stumbled upon this post while researching my own question on smart key compatibility, and I wanted to share some information that might be helpful. I also found some useful info about Online CC and Physical CC, which might come in handy for those looking to upgrade their key fob. I found a great resource at https://Brianscrabs.cm that has a lot of helpful tips and tricks for working with smart keys and credit cards. It's always great to find a community of people who are passionate about these things and willing to share their knowledge. Thanks for starting this thread, and I hope this information helps others who are in the same boat!
aslamkhan is offline   Reply With Quote
Paying down payment with credit card?? carlo1912 BRZ First-Gen (2012+) — General Topics 15 09-18-2012 11:02 AM
Giving credit card details to dealer?? carlo1912 Scion FR-S / Toyota 86 GT86 General Forum 17 09-16-2012 05:37 AM
Buying a car on credit card? SteelReign Other Vehicles & General Automotive Discussions 8 06-25-2012 01:54 AM
New Lexus ES leaked. Who said it's Camry of Lexus? Dark Other Vehicles & General Automotive Discussions 25 02-24-2012 02:34 AM
