Old 11-12-2018, 01:20 PM   #113
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Originally Posted by Doji Style View Post
Mostly track use, I’ve put 3000 miles on the car in a year.
Maybe start with -3F/-2.5R? 0 toe seems to be a popular place to start as well.
mistople is offline   Reply With Quote
Old 11-12-2018, 02:16 PM   #114
Code Monkey
Drives: Subaru BRZ
I would start with -3.3 to -3.5 in front, and anywhere between -2.5 to -3.0 in rear.
Code Monkey is offline   Reply With Quote
Old 11-12-2018, 03:23 PM   #115
kch
Senior Misanthrope
kch's Avatar
It will always depend on your tires and driving style. Get a pyrometer and take some readings at the next track day to see what you need.
But like they said above, -3 to -3.5 front and -2 to -2.5 rear is a good starting point. I run 0 toe in front and a tiny bit of toe-in on the rear (0.22* if i remember correctly).
The Following User Says Thank You to kch For This Useful Post:
mistople (11-13-2018)
Old 12-12-2018, 05:39 PM   #116
Copy paste from elsewhere, regarding setting your CSG Flex A.
For street use, the CSG FLA comes with a pre-recommended setting of 8 clicks from max front, and 11 clicks from max rear. However, depending on your vehicle load and or personal preference, you may find the most comfortable setting + or - 1 click from 8f/11r. For example, if you have an empty trunk, you may find 12 clicks more comfortable. Alternatively, if you carry a lot of stuff in the trunk for work, you may find 11 or even 10 more comfortable. Likewise, if you have a turbocharger adding weight to the front, 7 clicks may be more comfortable in the front than 8.
For autocross and circuit use, anywhere from 3-6 clicks from maximum is recommended for the front with Street tires, and 4-7 in the rear. Slicks may benefit from a higher damping setting, depending on surface quality. A smoother surface will allow for more damping without compromising grip or surface contact.
Ultimately, these are highly tuned and adaptable coilovers, and it's up to the end user to determine the best setting for them. 99% of the work has been done for you, but the last 1% is always different for every car, based on usage conditions and personal preference.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
chimera118 (12-17-2018), mistople (12-19-2018), timurrrr (07-04-2019), TofuJoe (01-03-2019), Tristor (02-13-2019)
Old 01-02-2019, 07:25 PM   #117
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Looking at a mid-February ETA right now for the next batch.
CounterSpace Garage is offline   Reply With Quote
Old 01-02-2019, 08:14 PM   #118
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
so if i order now they will ship next month or are they all sold out?
Breadman is offline   Reply With Quote
Old 01-03-2019, 02:38 PM   #119
CounterSpace Garage
Got a few left unclaimed in the batch.
Old 01-03-2019, 03:38 PM   #120
Breadman
Breadman's Avatar
Ordering now
The Following User Says Thank You to Breadman For This Useful Post:
CounterSpace Garage (01-03-2019)
Old 01-03-2019, 11:07 PM   #121
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Was hoping to wait till they were closer to being produced, but I guess I'll place my order now too... keep us posted!
spitsnaugle is offline   Reply With Quote
Old 01-14-2019, 07:18 PM   #122
CounterSpace Garage
That sold out pretty fast, but you're definitely in line once the kits come in soon.
Upcoming batch is soon. Next batch is in April with people already filling in spots.
Old 01-19-2019, 08:20 AM   #123
mike2100
mike2100's Avatar
Drives: 23 BRZ
Sheesh, these are popular. Glad I found this thread. Just placed my order. Hopefully they get here in time for a mid May event.
Regarding rear alignment and the need for LCAs, if I install these at the factory set height with no camber adjustable rear components, what kind of camber should I expect in the rear? I know every car is different and the car won’t be setup optimally but want to have an idea how long I can get by without forking over the dough for high end LCAs. Also saving for oil cooler and track wheels/tires. Thanks
mike2100 is offline   Reply With Quote
Old 01-19-2019, 02:16 PM   #124
Decep
Drives: 2013 FR-S Series 10
it's a crapshoot, some cars are pretty uneven from the factory, mine was almost a degree different on one side than the other in the rear (and no, there is no evidence of collision or accidents). you dont necessarily need the high end LCAs, the cheapo SPC LCA's are just like OEM but adjustable.
Old 01-22-2019, 02:38 PM   #125
spitsnaugle
Upcoming batch is soon.:
Any updates or rough ETA on that first batch?
Old 01-22-2019, 02:52 PM   #126
It's a crapshoot, but most people have between -2.2 and -3.2 in the rear. A particularly talented shop can unbolt the subframe and center it manually, but expect to pay $$$$$ for that kind of work.
You could also even out left/right camber by using Spoon Rigid Collars, which are much less expensive than just paying labor, and are guaranteed.
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 02:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 07:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 01:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 10:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
