86WORX
Old 07-08-2018, 10:49 PM   #71
mixxxx
mixxxx's Avatar
CSG Flex A is Corkscrew tested during the recently concluded Round 6 of 86Cup
mixxxx is offline   Reply With Quote
The Following 2 Users Say Thank You to mixxxx For This Useful Post:
Barefootdan (08-17-2018), TurtReynolds (07-09-2018)
Old 07-09-2018, 03:56 PM   #72
TurtReynolds
TurtReynolds's Avatar
Drives: 2017 Toyota 86
So, in my last post I touched on how Grid Life just didn’t go well for me. Well, a week later and I got to head back to the same track in “full” configuration; Autobahn Country Club in Joliet, IL. This time the weather and driver were in much better condition!
After some thoughts I reduced stiffness up front to 6 clicks and kept the rear at 7. Both counted from stiff. The result? Amazing. Compliance on the car went way up and it just felt so right. This was the sweet spot I had been looking for on this track and it led to me running consistently faster and more aggressive laps. I even posted my best lap ever on this circuit at 3:04! Precious best was 3:07 a year ago on RE71 with stock suspension and a stiffer front bar. This time I was on the GT Radial SX2. By all accounts a “slower” tire. Feeling myself just get more and more comfortable with each lap just blasted my confidence into the sky. It was amazing.
Videos below for the curious.
I know I still need more work as a driver, but this is the best I’ve ever done thus far.
TurtReynolds is offline   Reply With Quote
The Following 2 Users Say Thank You to TurtReynolds For This Useful Post:
Barefootdan (08-17-2018), CSG Mike (08-17-2018)
Old 08-17-2018, 03:53 AM   #73
hellaslammed.
https://i.imgur.com/Z6pGsgU.mp4
TurtReynolds (08-22-2018)
Old 08-17-2018, 02:29 PM   #74
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Definitely seems like 6-8 is a great sweet spot for these on most tracks. Mike, is there a good way to tell if you’re running too soft of dampening and could benefit from going stiffer?
Barefootdan is offline   Reply With Quote
Old 08-17-2018, 09:04 PM   #75
Yes, but you'd need a bit of seat time to recognize when the car is underdamped. It'll become easier once you go through the range of damping.
For now, keep upping the damping until you start getting hopping or a loss of grip where you did not previously. This will vary by car setup and track conditions.
Once you get that loss of traction, back off the setting 1 or 2 clicks. Unlike most coilovers in this price range, each individual click is meaningful.
Barefootdan (08-19-2018)
Old 08-18-2018, 06:21 PM   #76
alf
alf's Avatar
what is an expected time/miles between full rebuild?
is given the cost of FLA, rebuild a viable option anyways?
alf is offline   Reply With Quote
Old 08-18-2018, 11:11 PM   #77
Depends on your driving conditions and how you treat them. It could be as short as 45k miles, or as long as 90 miles.
Rebuild is totally a viable option. These are not throwaway dampers.
Old 08-20-2018, 09:54 PM   #78
alf
alf's Avatar
Thx for info. My '17 PP dampers lasted about 25k (s)miles. I mean they still work but that wonderful feel of precise rebound holding suspension in stable position and releasing slowly is gone. My driving style does not promote longevity ...
Old 08-20-2018, 10:26 PM   #79
alf
alf's Avatar
Sweet picture, but I wonder why rear is way more compressed here. Because your run 6ksquere, it is rear is too soft?
Old 08-20-2018, 11:09 PM   #80
norcalpb
norcalpb's Avatar
Has anyone compared these to a RCE yellow/B6 Bilstein combo? Or is a better comparison the Bilstein B8 as the Tein Flex A might have reduced droop travel?
Old 08-21-2018, 01:53 PM   #81
CSG David
CSG David's Avatar
The CSG Flex A has been preferred over shock replacement and lowering spring combos.
Old 08-21-2018, 02:01 PM   #82
Wangaroo
Wangaroo's Avatar
Drives: 2014 Varis Arising II FR-S
I believe it's due to the resultant motion ration from the multi-link rear suspension. If the springs are 6k square, the rear spring rate is closer to 4.5k
May also be caused by throttle
Wangaroo is offline   Reply With Quote
Old 08-21-2018, 02:23 PM   #83
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
Yeah you pretty much go full throttle from the top of the corkscrew until the next turn in, so I'd bet it's at least partly due to acceleration.
Edit: That is coming out of the corkscrew at Laguna Seca right?
Horrid_Funk is offline   Reply With Quote
Old 08-21-2018, 07:22 PM   #84
That's coming out of the corkscrew; the car is seeing almost 2G there, vertically, momentarily.
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 02:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 07:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 01:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 10:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
