#365 | |
Drives: 2022 GR86
#366 | |
![]() If you're looking for more rotation, I wouldn't recommend more than 6/7 split. Most folks consider the 10k/12k race rate setup too loose with 13-16 rear sway. Are you seeking more rotation at turn-in, mid-corner, or corner exit? |
#367 | |
If you want a track oriented damper, I would recommend considering a JRZ Motorsport, KW Clubsport, etc., something that is specifically designed for track use, with no compromises that originate from being designed for street drivibility. While not optimal, you can go up to +2kg on the damper; the rebound valving can handle it. I'm frankly surprised you find this too understeery/pushy for you with a 17 rear sway, as I find it pretty rotation happy, and I'm considered by most to be a very "loose" driver. I'll be the first to complain of a car doesn't rotate. |
#368 |
Drives: 2017 Subaru BRZ PP
I'm either going to try a 1kg/mm stiffer rear spring, or a stiffer rear sway bar. Problem is that I don't understand how much stiffer they are than stock in terms of overall spring rate.
For example, if a company lists the sway bar is 25% stiffer than stock, how would that compare to a spring rate increase? Would that be the equivalent of a 0.1, 0.5, 1kg/mm? I have no idea. I don't want to install a sway bar and it ends up too stiff on the softest setting or too soft on the stiffest setting. It would be a lot more convenient though as I could quickly set it up for more rotation in the canyons and more stability at the track |
#369 | |
#370 | ||||||
Drives: 2022 GR86
Although haven't done the math, that's been something I wanted to do for a long time .Roll resistance at each axle is neutral, yes. The benefit of "flat ride" is that on bumps that hit both sides (e.g. surface changes on a highway; crests, compression zones on a track, etc.) the chassis reacts with primarily up-down translation movement, and virtually no oscillations in pitch. That happens even when there's little to no damping, as springs themselves have an anti-resonance to such inputs to the chassis. The theoretical benefit on the track is that both ends of the car compress/droop in sync, causing neutral reaction to such bumps; instead of oversteer/understeer balance oscillations. Quote:
In fact, the first time I went to the track after installing CSG FLAs, I almost spun out of T3 at Thunderhill driving the way I used to drive with PP suspension. I was using recommended rebound settings for track. Perhaps because of the bumps there? No other changes were made to the car since the previous track day; only coilovers and alignment. I have since adjusted my driving and tweaked the damping for a balance that I like overall (5 clicks front, 6 clicks rear). My primary complaints with CSG FLAs are harsh ride in the front on major bumps (has nothing to do with the rear spring rate), and noticeable pitch oscillations (front/rear rocking) at highway speeds with street settings (8 clicks front, 12 clicks rear). I don't feel these oscillations on the track using track settings, but there can be other explanations here, such as
Even if the explanation is that extra damping helps stop those oscillations, that doesn't mean that the suspension works effectively when they do so. Quote:
Thanks for the idea! Quote:
I haven't tried 6/8 or 6/9 on the street, but my friends who have those setups street drive their cars too. I understand that stiffer rear springs will make the rear stiffer (duh). But given that the front is already much more harsh than rear, making the rear stiffer might not really make much of a difference to the overall comfort. Especially given that "flat ride" is exactly all about having similar effective suspension stiffnesses at both ends of the car. Quote:
This is a good strategy to make buying these coilovers "cheaper" initially. But I wonder if CSG FLAs could provide an optional alternative spec designed to work with specific aftermarket sway bars instead. After all, sway bars are some of the easiest to change and adjust components in the suspension; and given that CSG FLAs were so popular among 86DC participants. Sorry for a longread, but if this helps in development of any future CSG Spec coilovers I'd be very happy! |
#371 | |
Drives: 2022 GR86
A complicated answer that I do know is:
| The Following User Says Thank You to timurrrr For This Useful Post: | Var (07-10-2020) |
#372 | |
#373 | |
Drives: 2022 GR86
#374 | |
Drives: '14
Ride height will have a noticeable effect on the car's balance. It would be good to keep in mind if you're planning major changes there. |
#375 | |||||
Recommended settings are a blend of functionality and aesthetics. The As you previously mentioned, you get a lot of HBS engagement on the street. Raising the car will reduce that. There are quite a few adjustable settings on the dampers, and it's definitely not a 1 size fits all. Quote:
The damping combined with a 6/6 rate ultimately nets more performance than stock, combined with a nicer ride than stock. |
#376 | |
for example, the SPL RLCA changes motion ratio when you adjust camber by making the RLCA longer or shorter. This also changes the lever ratio. The vast majority of folks out there neither feel or realize this, because the net effect is miniscule. You also change rear motion ratio when you change wheel offsets, but most people don't notice that either. A few eagle-eyed folks have noticed I run lower offset front than rear. |
#377 | |
Each click is meaningful in damping adjustment. However, individual drivers' preferences will vary, regardless of speed or experience, as well as other components on the car. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | nlopez (01-07-2022) |
#378 | |
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 02:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 07:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 01:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
